Rear Hatch Cig Lighter
Ducky, have you used it recently?
I know on the older rigs like mine, the stock one up front uses a fusable link wire within a few inches of the outlet on the power wire.
It it blows, no juice.
That happened on my '90 truck I use to have, and I simply eliminated the fusable link altogether.
Yours may have one back by the outlet in the power wire, and it could have blown from running something to long back there.
I blew my mine out using an air compressor.
Check the outlet itself. The cig lighter outlet in my truck has a "fuse" in the outlet assembly. It is a small wire-fuse on the back of the outlet. Mine blew/melted when I was running a air compressor.......I searched the fuse panel and found no blown fuses. It wasn't until I removed the outlet and inspected it that I found that 'fuse' int he outlet had blown. I "repaired" mine by soldering in a wire jumper in place of the melted wire-fuse......I felt that the fuse in the fuse box should prevent any fire hazard
Hope this helps.
David
Hope this helps.
David
I think I know what did it too
Ill check to see if thats the case and jump it....
make a long story short, when welding my sliders on I only disconnected my neg terminal.... heh... It prolley got smoked by the welder...
:pat:
:pat:
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-14-2015 10:23 AM
