Rear end leaking.
if it's coming from the 3rd member-to-housing seal then yes, RTV is the preferred repair. pretty simple repair, just be careful of damaging axle seals when removing axles to pull your diff off. if you're draining and servicing the diff it might not be a bad idea to replace drain plug with magnetic low-profile version. good luck!
I got tired of waiting for a reply and went ahead and tore into it after I realized I've done this repair 100 times already a work. No biggie. Thanks for the reply though.
I simply meant some mechanics work on one brand of anything throw something else at them they panic .
I work with them on a daily basis .
Then you stated I did this repair a 100 times but yet you had to ask for help then you were so inpatient till you saw it was like similar things you had done.
the1998sr5
15
07-14-2020 08:35 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
