Rear E-locker and 4.30 gears
Old 11-23-2008, 10:07 AM
nfrantz007's Avatar
So I am looking at finding a used Elocker in the near future and from what I have seen they came stock with 4.30 gears. I would like to find all of the rear internals including locker, gears, etc and swap the front to 4.30 (97 4runner: stock 4.10 gearing).
***Also important to note I don't want an air locker
The question is:
1. Should I just find the locker and buy new gears?
2. I run 265/75/16 and would like the gear ratio to remain relatively stock. Since the stock tire size was an inch shorter the switch from 4.10 to 4.30 is only about a 5% decrease in gearing when the new tire size is factored into the equation.
3. If 4.30 gears is my best option(for what i want), where can I find 4.30 gears for the front? (checked a few places and only saw 4.56)
4. Am I stupid to want 4.30 or should I just get 4.56 gears? (I drive about 95% highway but when I do get off road I like to find the trucks limits...)
Thanks!
Old 11-23-2008, 10:21 AM
d0ubledown's Avatar
get the elocked 430. then find a front 430 diff n swap it out...its pretty easy. 430s are fine for 32's...even 33's. dont bother with 456's. if you want to regear, go 488's but then you're looking at regearing both ends...and since youve got the front open might as well throw in an ARB...and then...and then...etc.
keep it simple and keep the 430s.
Old 11-23-2008, 10:23 AM
4Runner202020's Avatar
some e locked rigs came with the 4.10... i am selling some 4.3's thought. lol
bobby
swaycleveland's Avatar
car-parts.com theres plenty of elockers with 430s on there
Old 11-23-2008, 01:45 PM
02SE's Avatar
bobby
Yep, factory E-locker and 4:10's here. If you like the gearing you have, I'd just get a 4:10 geared E-locker.
Old 11-23-2008, 01:51 PM
TacoNut's Avatar
My E- locker has 4.10s
Old 11-23-2008, 07:06 PM
nfrantz007's Avatar
Thanks for the information everyone.
I know the e-locker came with 4.10 stock as well but I want the 4.30's to make up for my larger tire size as well as the increase in rotating mass. I can definitely feel a difference when I go back and forth between the 265/70 and 265/75's (I have two sets of wheels and tires) and when I tow my trailer and bike I can only imagine I will be disappointed.
I'll be in purchasing mode in the next few weeks if any one has what I'm looking for... 4Runner 202020????
Thanks again!
Old 11-24-2008, 02:39 PM
crolison's Avatar
If you want the easiest I would try and find a 4.30 front diff.
I will be selling my oem rear gears if you want to get a 4.56 front diff and change the rear.
Old 12-09-2008, 06:45 AM
Tommy Boy's Avatar
I have a 96 4runner and my rear diff is broken. I need another 4.30 elocker with ABS. Any Ideas or anyone have what I need. Thanks, Tommy Boy
96 4runner 4wd
95 4runner 4wd
Old 12-09-2008, 07:57 AM
wii_tarded's Avatar
argh!, all this as done is to confuse the (*^(&%$^&(%)^ out of me as far as what gearing I have. cuz i want to put an e-locker on the rear of my d/d 4runner
Old 12-09-2008, 11:40 AM
Ritzy4Runner's Avatar
Sounds like my next "SR5 to Limited" project. One option my 4runner did not come with and wish it had. Just called my Toyota dealer and found out my gearing is 4.10. NOt to hijack the thread, but if you plan on staying stock with wheel and tire sizes, what is the advantage to going to 4.30? What will it change as far as the odometer? Never totally understood the gear ration thing.
06-01-2021 01:51 PM
XtraCab
04-12-2020 05:25 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: Rear E-locker and 4.30 gears
