rear, drum brakes hardly work???
Old 04-13-2009, 09:14 PM
graybeard's Avatar
I haven't inspected them yet but what should I look for?
Old 04-13-2009, 09:27 PM
RMA
RMA's Avatar
Once you take them apart I think you will see the problem it will be pretty clear , or take some pics and post them.
Old 04-13-2009, 09:35 PM
SoCalPaul's Avatar
What are your symptoms?
Old 04-14-2009, 02:52 AM
One_96TR4's Avatar
Probably just need to be adjusted. When you pull the wheel before you pull the drum, spin them and see if there is a little resistance. If there is then there adjusted fine. They should just barely rub the drum when there adjusted right. How do you now there not working properly? Is it just the way it feels? I noticed these trucks tend to dive a little when you brake hard on them. Most of the braking if from the front. You can manually adjust the drum at the back of the drum or if you drive in reverse slowly and pull and release the hand brake it'll adjust them aswell.
Old 04-14-2009, 07:13 AM
stir_fry_boy's Avatar
Could be the imfamous rear axle seal oil leaking on your pads - causing that symptom. You will be able to see it. Hope you don't have it!
Old 04-14-2009, 10:43 AM
gpcollen1's Avatar
If that is your only symptom, listen to the above advice and adjust them. Simple as that most of the time.
Old 04-17-2009, 06:47 PM
graybeard's Avatar
rear brakes
OK, I notice the lack of rear brakes with going down a steep driveway or when backing my boat down the ramp. My front tires slide and the rears do nothing as far as I can tell. I've had this problem for a long time and the last time I changed my front pads I adjusted the rears but it didn't help. OH, no problem with rear seals.....yet!
Old 04-17-2009, 09:09 PM
SoCalPaul's Avatar
Are you lifted? might be your rear proportioning valve.
Old 04-17-2009, 09:39 PM
One_96TR4's Avatar
If your truck has ABS, I'd rule out the proportioning valve. ABS trucks don't have them. Maybe your wheels cylinders are siezed.
Old 04-18-2009, 04:44 AM
cRoW's Avatar
i just had to replace my rear axel seal.... and my rear brakes due to gear oil all over my brake pads... sad sad day....
miceal383
06-29-2015 12:27 AM
Lybrium
06-29-2015 12:19 AM
cchinny
06-25-2015 08:11 PM
Mr.Black
06-21-2015 10:17 AM
Quick Reply: rear, drum brakes hardly work???
