Rear Drum
Originally Posted by Roadtripr
No to highjack but will that give access to the lugnuts? I need to replace one of them.
Originally Posted by vtruong1
How do you get the drum off? My e brake is off, but the thing is still stuck.
Also, there should be some threaded holes (mine are 8 mm) on the outside of the drum. You can thread the right sized bolts into those holes (usualy 3 or 4 holes) and as you thread them in it will push the drum off.
Also, as already mentioned, a big friggin hammer can help speed up many automotive repairs.
Originally Posted by superjoe83
yes, once the drum is off, you can pound the old one out of the back and install the new one
In the picture above, you'll notice there are 6 holes in between each wheel stud. On the one nearest the hammer, there's an extra hole, and one across from that. Like someone else said, use two bolts in these holes, to push the drum off, you'll need a bolt with the right size thread, with about 2 inches of threads to have enough bite to push the drum off.
Thanks guys, I thought it was going to be an easy process. But after not being able to get the damn thing off, I dropped it off at a friends. Sitting in the hot sun tryin to get if off just wore me out.
Athansinis
07-27-2015 08:38 AM
CanRunner
07-20-2015 01:29 PM
icentropy
07-14-2015 10:23 AM
