rear driveshaft zerk broken off. help!
Old 05-21-2007, 04:19 PM
TRDrunner's Avatar
okay so i went to lube my drive shaft because i was getting vibration, and i noticed the zerk fitting was broken off. i could see where it hit the gas tank skid.
i could get a new one, but there is still a little piece in the hole still.
any ideas to getting it out or another way to lube because it is DRY.
Old 05-21-2007, 04:44 PM
d0ubledown's Avatar
same thing happened to me. took it to a shop, they drilled it out n put a new one in. not sure if they had to retap w/ new fitting. cost was minimal. i also got them to grind out that corner of the gas tank skid...so it doesnt happen again.
Old 05-21-2007, 05:03 PM
Yotapup's Avatar
Drill it out and use a screw extractor to remove it.Should not be in too tight.
Old 05-21-2007, 05:58 PM
TRDrunner's Avatar
what kind of shop did you take it to.
an auto shop or a machine shop?
Old 05-21-2007, 06:00 PM
Embfixer's Avatar
+1 on drilling and the extractor..
Old 05-21-2007, 07:01 PM
TRDrunner's Avatar
drill out with what?
just a regular drillbit?
Old 05-22-2007, 01:53 AM
cox380's Avatar
You must use a special zerk fitting drill bit ONLY!
Old 05-22-2007, 05:32 AM
toy_tek's Avatar
Regular drillbit will work, but ideally you would use a reverse drillbit so if it snags it just unscrews the zerk. Reverse bits are awesome for that kind of stuff. I have a Snap-On set of 5.
Drill undersize and use a screw extractor, also called an Easy-Out (available at sears)
Actually I have the same issue, broke it off after I lubed it up. I'll get it next time 'round.
Old 05-22-2007, 09:17 AM
BruceTS's Avatar
just use a small EZ out screw extractor, the hole in the center is large enough....
There is no need to use a "special zerk fitting drill bit"
If for some reason it won't come out get the proper drill size, then use a 6mm x 1.0 tap to clean out the treads. I finally ended up putting a set screw in mine, after breaking about 10 of them off.
Old 05-22-2007, 10:07 AM
tacoma728's Avatar
I'd say check out auto zone or walmart
the1998sr5
15
07-14-2020 08:35 PM
raptor510
02-17-2017 07:11 AM
Ladythump
22
11-09-2015 08:53 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: rear driveshaft zerk broken off. help!
