Rear disk brake
Rear disk brake
Many moons back, while doing research on one of the jeep sites I happened accross a bloke who had done a rear disk brake conversion. This was done to a toyota axle that came standard with drums.
He had used a front axle ball knuckle section, cut away all the meat, reversed and bolted onto the rear axles, allowing him to use the standard toyota calipers, rotors etc.
Has anyone come accross something similar, or another home mod that i can do to add disks on my rear axle
I have only seen that done on Land Cruisers. I'm sure its out there and tonight maybe one of the hardcore wheelers will post some info for you. Good Luck!
Front Range Off Road Fab has a rear full floating axle/rear disc brake swap kit for like $699. It requires but does not include front locking hubs (79-85) and front brake calipers from an early Supra as well. Check it out:
www.frontrangeoffroadfab.com
This is on my long list of future mods. If I ever get to it, only time will tell.
There is a big write up on it in the July issue of 4wheel & offroad. Check out their site maybe it's there www.4wheeloffroad.com
Thanks shane ,
i had a look at the pics and that is what i'm thinking of, problem is though it will cost me an arm and leg to import to S.A with the current exchange rate.
I'll check to see if i can get something similar machined at a local shop.
Does anyone know of toyota calipers that have a mechanical linkage that can be used for handbrake. I the Nissan Skyline has this, but would like as far as possible to keep it toyota.
Originally posted by Shane
REAR calipers from an early Celica Supra.
Originally posted by kyle_22r
you could always get a driveline brake from allpro offroad, i think it's 289$, sounds interesting if i ever go to discs in rear
Check out http://www.sky-manufacturing.com/. The guys on the Pirate board say they are the company to use.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
