rear differential roaring/metal in diff oil
Old 01-11-2004, 06:25 AM
hub_01_69's Avatar
Exclamation rear differential roaring/metal in diff oil
i recently purchased a 91 yota 4cyl auto 4wd and noticed it had a roaring/whining noise from about 40 mph and up...really noticable at 60 mph...i decided to change the differential oil yesterday and found lots of metal shavings, a few small pieces of metal and the old oil was really thick...it is still roaring after the oil change...am i in need of a new rear diff? if so, would it be cheaper to just find one in a junk yard rather than having my current one rebuild?
thanks for any input
later,
Josh
Old 01-11-2004, 07:25 AM
Yoda's Avatar
Cheaper to get a used one. The V6 ones are stronger. Just make sure you get the same ratio as the front. When we bought our 85 it had a bad rear, we just changed it out.
Be sure to clean out the housing so the new/used diff doesn't get chewed up by the debris. We filled a sprayer bottle with ATF to wash out the crap. Also a magnet to attract the steel chips/flakes.
Old 01-11-2004, 09:17 AM
Robinhood150's Avatar
Used diffs can be found pretty cheap on various forums. Try looking in the for sale section of this board, 4x4wire.com and pirate4x4.com
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
87blyota
07-10-2015 04:31 AM
AaronM
07-08-2015 07:15 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear differential roaring/metal in diff oil
