rear diff is throwing gear lube
Old 04-25-2004, 08:04 AM
runnerof4's Avatar
yesterday i had a good day up in the mountains playing on some trails, i got home last night and i could smell gear lube so investigated the smell, it looks like the seal around the yoke is leaking and throwing fluid all under my truck, need help on what to do, should i take into a shop or try to fix it myself
Old 04-25-2004, 08:19 AM
kyle_22r's Avatar
sounds like the pinion seal. i know on older trucks like mine, the diff was setup with a solid spacer so you can change it yourself. i believe on newer trucks/4runners it's set up with a crush sleeve so it's best to take it to somebody who knows what they're doing
Old 04-25-2004, 08:35 AM
Robinhood150's Avatar
If it's not leaking too bad, you can live with it for a while. Mine's been leaking for about a year and I still haven't had to add any fluid.
Old 04-25-2004, 08:37 AM
runnerof4's Avatar
it leaking pretty bad, the whole underside by the rear end it covered in gear lube
Old 04-25-2004, 09:57 AM
Blair's Avatar
Piece of Cake
Sounds like the pinion seal. Part costs about $7.00.
Even a non-wrencher can do this one. I did. Took me three seals before I got it on straight
Just make sure you count the threads when you take the bolt off, and then put it back the same number of threads.
Biggest trouble was ensuring the seal is set straight, before you set it flush. Otherwise, it's easy.
Old 04-25-2004, 07:47 PM
apc
apc's Avatar
Just like Blair said, it is an easy fix. I did mine in under 2 hours. There is a large nut beneath the flange that is "indented" to prevent it from loosening up. The FSM say to replace this, which I did.
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: rear diff is throwing gear lube
