Rear Bucket Seats?
Rear Bucket Seats?
Has anyone ever replaced a 2nd gen 4runner's rear bench seat with bucket seats?
I was thinking about it, and I don't fold the back seat up that much. Mostly because the subs and amps get in the way in the back, and don't let me do that much more with folded seats.
I also don't carry more than one passenger very often, and don't really need 3 seats in the back. I was thinking if I pulled out the bench and put in two bucket seats, I could use the space in between for a center console; it could either be for storage, or I could fab up a housing for my amps right there.
Any ideas? Pics?
Any ideas? Pics?
That would be really sweet, I'd go with factory SR5 seats so that it looks classy and like a factory then put a factory Pickup centre consol (so you have dual compartments) between em.
Yeah, I was figuring on doing it the cheap way - junkyard seats from an SR5.
But two issues: the back seats don't need to slide (leaning back would be a nice option though), and I might actually get more clearance for my center console if I used some leaner (narrower) seats. Either something else from the junkyard, or cheap racing seats...
Hmmm..racing seats. Nothin' like having a 5-point harness in the back seat, right?
Funny, I am going to be doing this exact thing. I have a set of buckets from a 1990 Celica (leftover's from another project) that are going into the front of my 94' and was going to put the front SR5 seats in the back. I'll post up as soon as I get started. Or if any one has already done this please post details/pics.
I won't actually start on this for a while, but I figured I'd take measurements, anyway. It appears that on my '95, the front buckets would fit in the back, with minor modifications.
The shelf that the back seat is built on measured *just* long enough to fit the slide rails for the front seats, however where the floor bends up from the shelf to the bed is not a straight corner all the way across. The back mounting bracket on the seat rail may have to be adjusted (bent) to make the seat fit correctly.
It wouldn't be bad to have back seats that slid forward...you would be able to make your cargo space a little larger that way (zero leg room though). And with the front seats in the back, you'd also gain the space under the seats for a little storage.
I've seen a few posts that mention Celica (or other) bucket seats being swapped into Toy trucks & runners, like RLJ3RD mentioned. Are these seats a direct fit for mounting? Are they more comfortable (my runner's seats are the most comfortable I have ever felt!)?
terminator
07-27-2015 07:13 PM
sabine
07-18-2015 03:59 PM
icentropy
07-09-2015 02:12 PM
