Rear Axle / Wheel Bearing Removal Question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-23-2008, 08:40 AM   #1 (permalink)
After many hours of searching and printing guides. I think I am still missing a step. After trying to press off the ABS collar and ABS rotor last night with make shift ideas. I started thinking....(after getting some sleep)
Should the ABS collar and ABS rotor come off first via cutting shiselling or pressing before the "Special Tool" can be used. All my time spent trying to press the axle out in 1 shot will not work unless the snap ring is removed prior to pressing.
From looking at it it appears to be in this order
A) ABS lock collar
B ABS rotor
C) Snap Ring
D Bearing Lock Collar
E Wheel Bearing
Is my theory correct? Can someone confirm this?
I have my 3rd member coming back from ZUK and my 4Runner has been laid up for a few weeks and this renal car is killing my finances.....
Any tips, tricks, or assistance would be greatly appreciated.
Thanks in advance
John
foggysps is offline
Old 05-23-2008, 09:06 AM   #2 (permalink)
toytech76's Avatar
The first lock collar and abs ring need to be pressed off first. Then remove the snap ring. Then press the axle out of the next lock collar and bearing. Just remember exactly how far the first collar is from the bearing as the axle seal rides on it. If it is off, you will have a major gear oil leak. It might be worth it to take your axle over to a shop who knows toyotas and have them press everything for you so you dont need to worry about it
__________________
97 Runner. 4" Pro Comp IFS lift in the front, LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rear axle rebuild needed! Is it a do it yourself or stealership job! wheel bearing!! Ilovemountains 86-95 Trucks & 4Runners 11 08-10-2008 07:55 AM
Rear Axle / Wheel Bearing Puller Tool foggysps 95.5-2004 Tacomas & 96-2002 4Runners 6 05-25-2008 09:30 AM
Need bearing retainer for 85 rear axle. gonenomad The Classifieds GraveYard 3 03-24-2008 09:42 AM
Rear wheel bearing = tranfser case bearing? RallyRoach 84-85 Trucks & 4Runners 1 04-01-2007 11:41 AM
2009 InternetBrands, Inc.
