Rear axle shaft seal question
Old 09-18-2007, 11:09 PM
discosoup's Avatar
Does anyone know how far a axle shaft seal is supposed to be inserted in the axle shaft on a 97 4wd 4Runner?
Old 09-19-2007, 04:26 AM
mjwalfredo's Avatar
I just pounded it in as far as it would go with a hammer and a seal driver. The outer surface of the seal was about even with the beginning of the horizontal surface of the axle housing. What, I mean by that is the surface where the inner diameter stop decreasing if that helps.... I leaned to use Permatex "Right Stuff" on the outside of the seal to make sure it doesn't leak as well.
Old 09-19-2007, 05:25 AM
OSU4Runner's Avatar
Here is a good write up, should help you out.
http://4runners.org/writeups/rearseal/index.htm
Old 09-19-2007, 06:04 AM
mjwalfredo's Avatar
Good info Guapo. I am not trying to steal the thread but as I was reading that writeup I started thinking. If an axle seal leaks because of a clogged breather, does the axle seal really need to be replaced? I am guessing the oil would just seep between the shaft and the inner part of the seal right? Maybe there is some actual movement/damage to the seal when this happens or maybe it is just a good idea to replace the seal when you get a leak since you will have almost everything apart anyways? Any thoughts?
Old 09-19-2007, 11:50 AM
OSU4Runner's Avatar
I think it blows out the seal. Best just to replace the seal.
Old 09-19-2007, 06:25 PM
discosoup's Avatar
Thanks for the help.
Old 09-19-2007, 06:54 PM
4low's Avatar
and it buggers up your brake shoes too so I found out.
Old 09-20-2007, 03:25 AM
OSU4Runner's Avatar
Yep...my rear shoes were soaked in oil.....had to replace them and machine the drums...PITA
TURBOrunnerNM
07-22-2015 11:01 AM
andrewtexas123
07-14-2015 04:29 AM
Kalihi,HI
07-09-2015 04:29 PM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear axle shaft seal question
