rear axle seals leaking
once again my axle seals on my 99 4runner are leaking. i fixed the breathr tube that was clogged but i ahve an emergency and i need to travel 1800 miles. is there a possibility that i will loose the seal completly and all the fluid leak out or just taking a a risk of faulty brakes. will it continue to get worse. this is the 3rd time in 4 years
when you replaced them did you do it? if you did, have you been oiling the seal prior to instalation? if not your running a risk of burning up the seal and destoying them again and again.
no i didnt do it myself. the breather was no working properly. i did replace it myself. im just wondering if its safe to drive from florida to colorado and fix it when i arrive there, or am i taking a rish of it completly blowing out and loosing all the fluid and sitting on the side of the road waiting on a tow truck
How bad is it leaking? If it is a few drops at the time i wouldnt worry and check it from time to time. Buy the oil that comes in the rocket kinda shaped bottle so you dont need a pump to fill the pumpkin. If it is not gushing then i wouldnt worry to much. Mine leaks but it isnt the seal--it is the O-ring
Without being there it sounds like brake fluid. Has that been holding steady level wise? Whether it is brake fluid or Diff oil it will look like grease because it is mixing with the brake dust. Unless either one is leaking like crazy
The brake fluid has been fine. I havent filled it up in 8 months. When i noticed it low i ws hoping that was the problem, but where else would it leak fron inside the drum except the wheel cylinder which is nice and dry around it still...i dont think if it was axle fluid that the brake dust would get rid of the stink smell.
jerusry
10-19-2015 05:28 PM
