rear axle seal leaking
Old 10-28-2008, 03:12 PM
jrock's Avatar
I noticed my rear brake shoe's all corroded from the axles seal leaking. I heard the rear axles are prone to bending....anyone experience that?
Approx. how much $ for a new rear axle seal?
Should I go with OEM shoes or save some money and get these : http://www.wheelersoffroad.com/96024runnerbrakes.htm
I've got a 98 4rnr.
thanks!
Old 10-28-2008, 03:33 PM
Staff
DeathCougar's Avatar
With the real axle seal leaking, you will need the following parts
1-Axle seal
1-Axle tube seal
1-Axle tube o-ring
1-Axle bearing retainer
1-Axle bearing
1-C clip
You will need those parts at least, PER SIDE to do it properly. The axle must be pressed apart, thus the need for new bearings, lock collar, and C-clip. You will also want to replace the brake shoes, and i would suggest replacing all the springs/clips while you are in there. Thats exactly how I did my brakes when I had a leaking seal, and it worked out great. Besides that, it gives you the satisfaction knowing it will last another 100k miles.
While you are doing all that, unscrew the breather on the top of the axle and make sure its not clogged, or buy a new one. That breather being clogged is the #1 cause of axle seal failure.
Old 10-28-2008, 04:33 PM
littleyotathatcould's Avatar
those things are a bitch it took me three hours to do mine. and definately check that breather its what caused mine. be shure not to bend the backing plate ethier
Old 10-28-2008, 05:23 PM
jrock's Avatar
ok, thanks folks!
Old 10-28-2008, 05:47 PM
Staff
If you have to press it all together, then yea it can be a pain. But if you have a shop do all the press work, its a piece of cake. Just take your time to do it right the first time, and you will be set.
Old 10-28-2008, 05:56 PM
Skinsfan6's Avatar
Um, it's probably just the oil seal on the very end of your axle that is leaking. It's like a <$10 seal that sits right on the inside of the axle tube. This is what was leaking on mine. The inside of the drum had gear oil all in it. The shoes were saturated. You have to pull the drum/axleshaft out on the side that is leaking to get to it. It helps to have a seal puller (glorified claw hammer), but it can be taken out with a flathead screwdriver. I had to change mine four or five weeks ago. Right rear. Took me an hour and a half with no help. That included bleeding the brakes after reattaching the brake line. But it helps if you've pulled axleshafts before and know what to do.
Old 10-28-2008, 05:59 PM
Staff
If the actual axle seal is leaking, replacing the inner tube seal will not fix his problem. I had to fix just the opposite of what you are describing, as my axle seal, not the tube seal, was leaking.
Way i look at it is, why risk tearing it apart twice when you can do it properly ONCE and be done with it?
Old 04-22-2010, 08:46 PM
SDMF's Avatar
So Deathcougar, do you have those part numbers?
Old 04-22-2010, 09:42 PM
Staff
your local dealer can provide those part numbers, I do not have them off the top of my head and the only way for me to get them is to call Toyota.
Old 04-23-2010, 04:12 AM
habanero's Avatar
And make sure you or the shop doing the presswork takes note of where everything is placed on the axle- there's no spacers to tell you where to put anything.
Old 10-28-2010, 04:05 PM
kasko's Avatar
I agree with Death Cougar on the clogged breather. My 84 was always leaking and i finally realized one day the breather was bent and clogged from muddin.
Old 10-28-2010, 04:20 PM
streetlancer's Avatar
Check this thread for part #s and procedures:
http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
jakebarrett
07-10-2015 07:15 PM
Kalihi,HI
07-09-2015 04:29 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear axle seal leaking
