| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rear Axle Rubbing noise = damaged axle?
#2 (permalink) |
As per my experience and recent threads, the rubbing may be rerlated to the e-brake issue in that the shoes and components are all gummed up and sticking.
it is relatively easy and cheap to take the drum off, spray the entire unit clean, remove the axle to inspect. The only cost here is a can of spray cleaner and an inner seal if you want to put it back together. You can take the axle to a professional for inspection if you cannot do it yourself. This has been a hot topic recently - you can search and read too.
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending |
#3 (permalink) |
Thanks. I read in one of the thread to use a magnent to check for metal shaving. I've never pulled an axle out before, so I am unsure what to look for in a damaged axle. Advice?
#4 (permalink) |
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
Thanks. I called around here in the Santa Clara area, and the shops are quoting me about $400+ to press out the bearing + replace the seal ($75 + parts just to replace only the seals). The shops said a bad bearing is usually the main culprit, consistent with what 4Crawler provided (thx btw).
What should i be looking for to scout out bearing damage that may be causing this? I hope to take a look at it tonight, pending time. Thx for the inputs. |
#6 (permalink) |
You could start by pulling the drum off and cleaning everything up, lube the ebrake cable, put the drum back on and see if it is making any noise.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear axle blew out oil and now makes noise, what did I wreck | Dr.Trevorkian | 84-85 Trucks & 4Runners | 23 | 06-18-2007 07:35 PM |
| Wierd noise when stress on the rear axle... | Wife's 4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-12-2006 05:26 PM |
| 2wd rear axle vs. 4wd rear axle (newbie warning) | fustercluck | 86-95 Trucks & 4Runners | 3 | 08-08-2006 03:05 PM |
| Rear axle noise | George G | 86-95 Trucks & 4Runners | 2 | 07-08-2006 05:54 AM |
| Rear axle making noise | ToyoRunner94 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-03-2005 09:34 PM |
