Rear axle questions...
Old 12-24-2007, 02:30 PM
Rescue84's Avatar
I just got the adjusted appraisal in the mail from when I was hit a few weeks ago... now they have the rear axle housing added in (Replace OEM) -- is the housing any different for an axle w/ the factory rear locker as opposed to the housing without a factory rear locker?
Also, I've heard quite a few things about aftermarket rear axle seals... for the rear oil inner seal they have an "aftermarket new" written in but for the rear oil outer seal they have "replace oem". They have "aftermarket new" written in for the rear axle bearing as well. The rear axle seal is also "replace aftermarket".
Basically I'm just wondering if these parts are gonna hold up or give me issues as others have mentioned. Please give whatever feedback you may have regarding aftermarket vs. OEM and also if it's worth going through the hassle of having things switched out. I just want to make sure this all gets done right the first time.
Thanks in advance
Old 12-24-2007, 02:39 PM
Guest
seanz0rz's Avatar
yes, the housing for a rear locker is different than the standard housing.
stuff like axle seals and bearings, i would go with NEW OEM from toyota dealership, not from some 3rd party seller.
Old 12-24-2007, 02:42 PM
X-AWDriver's Avatar
Definetly use OEM seals since I've seen aftermarket ones fail after even just 10k miles.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear axle questions...
