Rear Axle leak at Pumpkin! - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-18-2006, 03:10 PM   #1
dbikeman's Avatar
My rear axle is leaking at the bottom of where the 3rd and the pumpkin come together. I checked the bolts and the bottom 2 were loose so i tightened them back up but is there a gasket or anything else that could have made it start leaking? I had the fluid changed back there about 6k miles ago. Anyone think it could have just come loose from the work?
dbikeman is offline   Reply With Quote
Old 12-18-2006, 03:22 PM   #2
da_bigg_wigg's Avatar
The fluid getting changed shouldn't have make your diff leak. I know that there is a gasket specifically for the pumpkin, but when I was changing mine I couldn't get a hold of one so I just ended up using some gasket maker. It's been nearly half a year with no signs of leakage. Of course, to take it apart just to change a gasket is a lot of work, but not difficult. If you don't mind getting dirty and have most of a day to kill depending on your skill, you can replace it pretty easily.
da_bigg_wigg is offline   Reply With Quote
FS[PacNorWest]: Rear chromoly axle shafts A2theK Axles - Suspensions - Tires - Wheels 5 01-10-2016 11:18 AM
FS[PacSouthWest]: 2- 8"3rd members:4.88 ratchet lockers,new setup kit, rear axle rebuild kit,diff armor jerusry Axles - Suspensions - Tires - Wheels 1 10-19-2015 06:28 PM
Leaking extention housing seal andrewtexas123 86-95 Trucks & 4Runners 3 07-14-2015 05:29 AM
Radiator leak. Now where to? (2000 v6) Avenged 95.5-2004 Tacomas & 96-2002 4Runners 4 07-09-2015 08:55 AM
1984 extra cab build up toyoda8488 84-85 Trucks & 4Runners (Build-Up Section) 2 07-05-2015 11:18 PM
Tags
2004, 4runner, 99, axel, axle, end, leak, leaking, lk, pumkin, pumpking, rear, tacoma, tahoe, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
