Rear Axle
Old 10-01-2009, 10:16 AM
Canadian Bacon's Avatar
Rear Axle
I sprung a rear axle and thus have to change out the seal. I have everything taken apart, but I need to take it to a shop to get the seal pressed out. I just phoned my local Toyota dealer and they recommended changing the bearing, all the seals, clip etc. because oil would have gotten through the bearing which would eventually cause it to fail. Is this a load of crap?
So should I just get the seal changed, or the whole deal?
Thanks.
Old 10-01-2009, 10:33 AM
874runnersr5's Avatar
I just did this, what seal is leaking? The one on the housing? or the one on the rear axle shaft?
Old 10-01-2009, 10:40 AM
nc994run's Avatar
Location: raleigh, nc for school chapel hill, nc for home
The axle seal can be pulled out with a seal puller IIRC
Old 10-01-2009, 10:44 AM
JFCruiser's Avatar
shouldnt be that hard now all you need is the parts and im pretty sure you can get it here at a really good price like i did
http://toyotapartszone.com
they even have hot spots to help you locate the exact part and diagrams to help you install it
LOVE THIS WEBSITE
Old 10-01-2009, 10:53 AM
I have a seal puller, so I can get at the inner seal. I'm talking about the outer seal by the bearing, the one on the axle shaft.
Regardless, I know I can get just the seal changed, but should I also change the bearing due to potential oil damage. Way I look at it, is pay for it now, instead of paying for it later. I rather have my truck in perfect working order seeing as the cold is coming fast. It isn't fun working in the garage once the mercury drops.
Thanks.
Old 10-01-2009, 11:43 AM
Might as well, your going to need a press to get the new bearing on
Old 10-01-2009, 12:32 PM
nc994run's Avatar
In that case, go ahead and have them do it all at once
Old 10-01-2009, 12:35 PM
That's what I was thinking. Thanks. Now if I can just get through to the servicing guy at Toyota. They must be really busy with everyone getting ready for winter. There was already frost on my windows last night.
Thanks.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear Axle
