| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rattling noise in drivers side dash. ideas?
__________________
'00 Tacoma 4x4 TRD Off Road 3.4 Liter 6 Cyl 5 spd manual 3" body, 3" suspension lifts |
#2 (permalink) |
unfortunately it could be several things. try taking the knee bolster down and see if you see anything that could be moving or rattling. Grab things and shake and see if u can replicate the sound. I had a similar issue and it was the harness to my remote start rattling against some stuff.
#3 (permalink) |
Are you sure it's not just your key fob hitting the dash? That one got me for a while.
MadCityRich
__________________
Alright, when I say your name, you say 'here.' And we will assume 'here' is short for 'here I am...rock you like a hurricane. -Ignignokt |
#4 (permalink) |
Chromatest, Have you had any luck finding the source of your rattle? I have the same problem in my 97 4runner.
#5 (permalink) |
I haven't sorted it out yet... I do know it's not the key fob.
__________________
#6 (permalink) |
I think there's a TSB about dash rattles in Tacos and 4Runners. Something about a bracket touching some metal part. I know mine has a rattle on the passenger side, but it's above the airbag and I've never been brave enough to remove it to check it out.
#7 (permalink) |
mine rattles, but it's missing a few screws in the cowl so it's an easy fix (if i ever get around to buying some screws..)
__________________
1994 Xtracab pickup, 180,000km 1987 4Runner, 510,000km |
#8 (permalink) |
From the .gov website, I don't see anything about it. You can do a search on your own vehicle here:
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
__________________
#9 (permalink) |
For what it's worth, I get a rattle in my driver door when the window is cranked all the way up. If I just tap the window down button (window is still closed) the rattle goes away. Good luck.
__________________
'98 4-runner, 5-speed, 3.4, e-locker & leather. Deckplate, Toytec 3" OME 881/891, Locker mod & 285/75/R16 Mud Kings. |
#10 (permalink) |
“Rattling noise in drivers side dash. ideas? “
Could be your wife or your girlfriend when one of them is driving your truck..? :-))) Last edited by progress4m; 11-16-2007 at 02:43 PM. |
#11 (permalink) |
that happens to me too it comes and it goes and itstarts up at about 20 miles per hour and then gets louder and sometimes stops and it is someties on the passengers side but mostley on the drivers side
#12 (permalink) | |
Quote:
Cheers
__________________
1997 3.4 4Runner, 5spd, e-locker, SS#1.1 Lift, 265/75/R16 Dick Cepek FCII Coming soon: ARB front bumper with T-Max or Warn winch, sliders, snorkel, etc. |
#13 (permalink) |
This might sound odd, but put your defrost onto full windshield, and crank teh heat and fan all the way up for a few minutes and see if that helps. My brother was telling me this used to happed to him in his '99 taco. I had/sometimes have something similiar and it helps mine.
__________________
2000 Toyota 4Runner SR5 Highlander Sport Edition 4x4 3.4L 5 Speed Bilstein Shocks 1999 Tallest Springs |
#14 (permalink) |
i hate to dig up an old thread, but did you ever figure the problem out. or does anyone have any info on the TSB for the dash rattle?
My 03 just started doing this tonight this is really starting to make me wonder, my 03 with 70k miles has almost as many problems as my 89 honda with 270k on it
#15 (permalink) |
I still haven't figured it out yet. One of these days I'll pull out my front seat so I have room to get down there.
__________________
#16 (permalink) |
Noises/rattles can be tough to find,because the sound bounces all arond the cabin....many moons ago I traced several that would happen more frequently when the outside temp would drop..Most of them comming from the dash area (rattle bouncing off windshield)ended up being loose dash clips...THE ONES THAT LOCATE THE DASH PINS WITH THE FIREWALL...they just need a couple wraps of thin felt/foam tape...Unfortunatly the entire dash needs to be removed..No easy task even for an experienced tech.
Only real short cut to possibly cut down on the noise if the rattle is comming from this area of the dash..is to jam in some foam backer rod along the whole length of where the dash and windshield meet....something like this,maybe 3/8 or 1/4 : http://www.mountainhomebuildingprodu...G-p-16204.html |
#17 (permalink) |
It's probly just a little rattling part, if you can locate it just secure it with some silicone or a zip tie. I have these in my truck but i just turn the music up a few notches
__________________
. . . I said lie, for me lying under a process tree . . . . |
#18 (permalink) |
thats what i was thinking last night, shimming the dash with foam. if i put my hand on the passenger side of the dash while i'm driving then it goes away
#19 (permalink) |
As mentioned by others, there are plastic clips that attach the dash cover to the firewall that can rattle. I was able to access mine by removing the gauge cluster and then cinching this area of the cover (left of the cluster) to the firewall with some wire. Worked well for me.
| Tags |
| backer, rattle, rod, tacoma |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Funny ticking noise coming from the drivers side rear... | Starbuck3733T | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 06-23-2007 08:14 PM |
| 99 3.4 weird grinding noise and water on drivers side? | justin1889 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-22-2006 05:29 AM |
| Funny noise from front drivers side wheel | Biohazard | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-10-2006 07:52 PM |
| strange rattling noise around the front passenger side kickplate | spacewrangler | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 09-10-2005 03:20 AM |
| Rattling Dash Trim | 4x4Fink | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-05-2004 12:07 PM |
