| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Radio light out-searched high and low...
#2 (permalink) |
Staff
Welcome to the family...
Most radio dispalys these days are actually either LEDs or liquid crystal displays so there is no "light bulb" [at least for the LEDs], if there is a bulb it would be internal to the radio and not accessable to the user. This is one of those times it would be better to go to a professional. I'd start by looking up a few car audio specialty stores in your area [not a big box store like best buy etc] and ask them about servicing your unit if you do the removal and reinstall yourself you may save some money. On the other hand you may find it cheaper to have an upgraded after market unit installed. just my 0.02 aviator
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#3 (permalink) |
Thanks! I can still see the LED display...
Just no green back light. I here what you are saying about professional help and I have a good local private source. I just have been in the mode of doing it all myself when feasible....
#4 (permalink) |
When the green light went out in my wife's radio in her '00 4Runner a couple years ago, I asked our local toy dealer how I needed to go about having it serviced. They told me they would have to send the radio off to be repaired. Said it would be at least a couple hundered dollars just to send it off! A new oem HU was roughly $600 +. Crazy I know...
So I started searching the Yotatech "Classifieds" section and Ebay for a used oem HU just like the one she had. (My wife did not want an aftermarket HU, so that was not an option.) Luckily, I found a member on here that had removed his oem HU to install an aftermarket one. He sold me the oem HU for only $25 shipped . It's been working flawlessly for 2+ years now.So unless you want to go aftermarket, sounds like you'll have to do what I did and search for a used oem HU. Good luck.
__________________
2002 4Runner Sport 4WD My 4Runner Profile Accessories: SS 7.1 Lift Kit, WabFab 1" BL, TJM T15, Stubb Sliders, FX/TSX HID Projector Retrofit, 1st Gen Rollbar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Nitto TG 265/75s, WeatherTechs, Hella HID 4000s, LED Tail Lights, JBL Speakers Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod & Rear Diff Breather Mod "Why fix a Jeep, when you can drive a Toyota?" |
#5 (permalink) |
Theres about 50 billion threads on this very subject right here in this very forum! I found all the answers I needed to fix mine right here
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#6 (permalink) |
As I stated, I have searched...hard... Really
I must be missing the correct key words. Any advice??
#7 (permalink) |
I had the same problem on my 97. I found a 97 OEM HU w/ 3 disc changer on Ebay for 27 bucks.
#8 (permalink) |
Update...tore into the radio
Pulled the radio out and disassembled it. If you remove the front black panel, it just has retention clips. There is a circuit board held by 6 very small screws. Remove the screws and the circuit board easily comes out. On the front side are multiple tiny lights attached to the board. I removed the one in the area of the display with a small slotted screw driver. I am going to an electrical supply store to see about getting a replacement. I will update again as I reach the next step. Hopefully It all goes well. I re-installed the radio for now and all is working as before, the LED station read out is still functional just not backlit, so removing the light does not effect things adversely.
#9 (permalink) |
FCBuff is right, pull the front face off of the HU and you'll see what I remember to be either green or grey round screw in plugs with some white glue holding them in. Carefully scrape the glue off and use a small flathead screwdriver to remove the bad bulb. I did it in my HU, works great now. I had a spare HU to use for parts though, might have another bulb or you can buy my spare and use all of the bulbs you want!
#10 (permalink) |
Terminator
Thanks, I just may take you up on that offer. I am going to check that store first just to see what they have...I haven't had a chance yet!
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A/C low/high side | mike powers | 84-85 Trucks & 4Runners | 1 | 06-19-2006 06:17 PM |
| Toyota CV joint... High angle vs Low angel??? | gmrwizard | The Fab Shop | 8 | 12-11-2005 08:07 AM |
| high/low beams | SIGSays | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 02-22-2005 07:14 PM |
| need your help with low/high beams and fog lights... | SIGSays | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-21-2005 06:38 PM |
| 22re: very high high idle, very low low idle | mike_d | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 11-14-2003 07:50 AM |
