Radiator Reservoir-near empty
Guys and Gals,
I was under the impression that the radiator reservoir should be between the full and low lines......Mine is always on the low side.....I was told at my 90,000mi service that the fluid level in the radiator level will vary while I drive and that I was probably only noticing it when it was on the low side......
My radiator seems full whenver I check.....and I have no overheating problems...also no leaks noticed....
Am I just worrying too much? TIA
Location: Far western Kentucky (transplanted from central PA)
Add coolant to the reservoir to the "low" line while the engine is cold. It should return to that level each time the engine cools down after heat-up. Otherwise, a hard-to-find leak or headgasket problem may exist.
kawazx636
10-06-2021 03:03 PM
scott90
10-04-2015 09:21 AM
