| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Quick Maintenance Question?!
__________________
John 97' Limited 4X2. SUSPENSION- OME Springs & Shocks / Addco Front & Rear Anti-sway Bars / Eagle 146 Chrome Rims / Bridgestone Dueller A/T's, 285/75/16. PERFORMANCE-Raceconcepts Cross Dimpled-slotted Rotors w/ PF CarbonMetallic Pads / Dynomax Super Turbo Muffler / Ractive Stainless Exhaust Tip / Hayden Transmission Cooler / Deckplate mod Airbox w/ Amsoil Airfilter / Mobil 1 Synthetic throughout. EXTERIOR- 20% Tint all-around / APC Clear Corner & Bumper Lenses / 99' Grill / Freeway Blaster Horns / EGR 3D Carbon Fiber Look Bugguard & Rear Dustguard / Cleared(orange) Taillights / Blind Spotz Mirrors / Pilot Back-up Lights / Removed Running Boards. INTERIOR - J. Burtman Woodgrain Kit / Check Hi-Lo Seat Heaters / Footwell Lights / Maglight Holder / Aluminum Pedals. |
#2 (permalink) | |
Re: Quick Maintenance Question?!
Quote:
2.)Is it 80w90 or stright 90. Anyway, most folks use the 75W90 Mobil 1 synthetic. I do. Not sure, but maybe Amsoil has the 80w90 or stright 90. Without checking, I believe 24mm sounds right. You are probably experienced, but a hint is to loosen the fill plug first. To make sure you can get oil back in. Pete
__________________
2000 silver SR5, 4x4, Locker (w/mod), diff extention, TRD cooler, HP brakes, Bilstein shocks, sans steps (Taco guards), Taco antennae, added backup lights, San Jose MP3, etc. No fancy just functional. |
#3 (permalink) |
Your in the army? In Georgia? You at Benning?
__________________
90 4 Runner 4x4 V6 Auto, Westin step bars, Eagle rims, DOA head port and camshaft. 94 Toy truck 4x4 22RE 5sp, 31x12.5 BFG muds, eagle rims, Rancho RS9000s, nerfs, ext. shackles. SOLD http://community.webshots.com/user/williemon |
#4 (permalink) | |
Quote:
No problem on the Spark plugs, they are the correct Part #. Did you use plent of anti-seize and torque to the correct value?? 75W-90 is just fine all around. I am currently using 75W-90 in the Manual Tranny, front diff, and rear diff. The drain/fill on the rear diff and manual tranny is 24mm. The drain plug on the front diff is a 12mm hex and the fill plug is a 10mm hex. Best of Luck Andrew
__________________
96 Runner SR5, 4x4 97 Volvo 850 GLT "Rice Killer" |
#5 (permalink) | |
Quote:
Instead, I'm at this hellhole called Ft Stewart. I know the old saying: " the worst duty station is where your're at, and the best one is where you just left or getting ready to go to", but I can say without a doubt this is the worst duty station/area I've been at in 10 years! ![]() BTW, thanks for the responses; I left in all 6 NGK plugs and went with 75w90 Mobil 1 sythethic for the rear diff. It was a 24mm bolt for both the fill and drain.
__________________
John 97' Limited 4X2. SUSPENSION- OME Springs & Shocks / Addco Front & Rear Anti-sway Bars / Eagle 146 Chrome Rims / Bridgestone Dueller A/T's, 285/75/16. PERFORMANCE-Raceconcepts Cross Dimpled-slotted Rotors w/ PF CarbonMetallic Pads / Dynomax Super Turbo Muffler / Ractive Stainless Exhaust Tip / Hayden Transmission Cooler / Deckplate mod Airbox w/ Amsoil Airfilter / Mobil 1 Synthetic throughout. EXTERIOR- 20% Tint all-around / APC Clear Corner & Bumper Lenses / 99' Grill / Freeway Blaster Horns / EGR 3D Carbon Fiber Look Bugguard & Rear Dustguard / Cleared(orange) Taillights / Blind Spotz Mirrors / Pilot Back-up Lights / Removed Running Boards. INTERIOR - J. Burtman Woodgrain Kit / Check Hi-Lo Seat Heaters / Footwell Lights / Maglight Holder / Aluminum Pedals. Last edited by Lifer; 08-08-2002 at 01:24 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Quick question Quick answer re CB | Expat | GPS & Communication | 18 | 03-08-2005 09:52 PM |
| Quick heater maintenance before winter story... | Fahrenheit 451 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-26-2004 08:40 AM |
| Quick question on quick disconnects... | WSU4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-25-2004 07:27 AM |
| I need a quick answer for a quick question | Tacoma Dude | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-22-2003 01:37 PM |
