question on lifting rear of tacoma
Old 01-07-2008, 10:31 PM
hiloracerboy84's Avatar
ok, well i put a lift on my 4runner 3 weeks ago, and now im probably going to sell it and look for a tacoma. ill be taking the ome parts off of it, and putting it back to stock before the sale, and will reuse the front setup in the tacoma. my question is, whats the difference between the shackle and add a leaf options on lifting the rear? anyone care to shed some light on the pros/cons of each, and any other options there are for lifting the tacoma? any recommended bodylifts for it? thanks
Old 01-07-2008, 10:40 PM
fillsrunner4's Avatar
Umm the taco front compared to the 4runner should be the same but to match the front to rear lift to make the truck even depends on how big the 4runners lift actualy is? and that is??? What you could do is make a bit longer shackle and add a small block if the shackle isnt long enough. again depending on the front lift? The block wont be good for wheeling as it can warp and hurt you on the trail Id get some bigger springs to match the front but if its a small lift just put in a longer shackle to compensate
06-01-2021 01:51 PM
87turboPA
07-12-2015 07:49 AM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: question on lifting rear of tacoma
