| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Question about vacuum throttle opener to SC
__________________
2000 4WD 4Runner Sport, auto, 5VZ, SC, URD fuel kit, 2.2" pulley, 4" deckplate, Trueflow filter, Airraid mini intake, TRD Exhaust, trans cooler, IPT Valve Body, TrueTrac rear, SS 7.2, 285 75R 16 BFG ATs on PC'd LX450 wheels, JAOS color matched Spoiler, Line-X'd stubbs sliders 07 Kawasaki Brute Force 750i, stock for now |
#2 (permalink) |
Hook everything up correctly and pull the EFI fuse and relay under the hood in the black fuse box for a night, or just for a few hours... This will reset your fuel trims that have been ruined since your computer has been trying to compensate for the extra air it was "magically" pulling from the open tube (this occured since the leak was behind the MAF sensor). Go ahead and hook the fuse and relay back in and start the truck and let it idle for 2 or 3 minutes or until its nice and steady around 650-750... then drive it and see what happens!
__________________
1999 4 Runner 9.9 sec 1/8 mile on 7 psi and fuel injectors only (NO Alcohol) weak tune! TRD Supercharger, Alcohol Injection, Walbro fuel pump upgrade, Custom 2.5" stainless exhaust, 3" Tundra/LC Coil Lift, 1.5" 4Crawler BL, 305/70/16 Mickey Thompson MTZ's... Next: HID Bi-xenon Conversion, Tundra brake upgrade... |
#3 (permalink) | |
Quote:
__________________
#4 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#5 (permalink) |
That fixed me. Thanks guys...
I understand what was going on now. Additional air coming in not read by the MAF was causing a semi lean condition. After the ECU adjusted to that additional air coming in (after the throttle body mind you) when I cut it off without reseting the ECU it would die because that additional air was no longer there.
__________________
#6 (permalink) |
You're going to have to adjust your fuel map on the FTC also, use Gadget's U-Tune guide. Do you have Wideband?
__________________
Brian 1998 4Runner SR5 |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
Glad that worked out for you... Lay down any dyno numbers?
__________________
#9 (permalink) |
No dyno runs. I'm just going to road tune it for now with no real plans to dyno it.
__________________
| Tags |
| 1998, 4runnervacuum, diagram, routing |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Vacuum Question 81 Toy | trekker81 | Pre 84 Trucks | 0 | 06-29-2007 02:05 PM |
| Another TRD SC Question | 4Runner94115 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 07-11-2006 06:51 AM |
| SC/URD question | turboale | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 04-22-2005 01:18 PM |
| TanYards - Greeville, SC and personal Land in Roebuck, SC : A day of wheeling | Stegall984R | Trip-Trail Reports & Photos | 91 | 03-17-2005 02:35 PM |
| Supercharger vacuum lines question | pfdaxe | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-09-2002 01:21 PM |
