Question about ISR mod on 3.0
Old 07-23-2005, 07:12 PM
msuguy44's Avatar
I am considering doing the isr mod on my 94 runner with a 3.0. I did a search and some of you all talked about the intake being louder. How much louder is it, and does the increased noise really bother you? Thanks for any responses
Old 07-23-2005, 08:17 PM
Guest
94x4's Avatar
It's not loud at all, that is, unless you are standing outside of the vehicle and/or are gunning it, as is the experience with mine.
Now, I can hear it with the window down, sitting at a stop with the window down alone (no other vehicles around), but when I really hear it is when I step on it as it is able to suck in more air without all of the restrictions in the way..., this is what I think people mean when they say it is "louder".
Old 07-24-2005, 12:45 PM
JZX100's Avatar
yea its pretty quiet, u will notice the difference in tone but i dont think its loud. some may think its irritating but, i dont think so at all...
Old 07-25-2005, 06:00 AM
geneius's Avatar
I just did mine and it was a bit loud...sometimes. Here's what I mean>> After doing the ISR mod, I noticed:
1) A hissing noise coming from the air-filter box (Yup, checked all the vacuum hoses, seems okay)
2) I took off that little box next to air filter and connected the two hoses that were stuck to it. Now, at idle, it makes a low-pitched grumbling noise. Sounds mean, but gets irritating after a while. I'm thinking about putting that box back on so that it will get a bit quieter at idle. (I want it loud at WOT not while sitting at the traffic light).
Is this normal? From what I read, it's not. If someone can give a tip, it can help me and may be useful to msuguy44 should he come across this.
Oh, BTW, here's a pic of my mod:
Old 07-25-2005, 09:23 AM
JL8Jeff's Avatar
I left that little box off at first as well. But when the AIR system opens up you get a really annoying sound from those hoses. So I put the box back in the truck and put a breather on the hose that used to go to the stock airbox. I'm running an open element air filter as well. That little box is a silencer and it does it's job well.
Old 07-25-2005, 09:33 AM
Flamedx4's Avatar
I drilled two 2" holes in the bottom part of the airbox and nothing more. Sounds the same at idle and on light accelleration, but it noticeably louder when pedal down. It's not annoying, but I wouldn't describe it as pleasant tone either. No noticeable difference in performance that I can see.
Old 07-25-2005, 09:39 AM
geneius's Avatar
I haven't noticed much HP gain, just dB gain... So, I'm gonna put that little black box back in when I get home today.
Old 07-25-2005, 09:47 AM
Guest
94x4's Avatar
Yes, replacing the silencer that had to 5/8" hose running to it will resolve that issue for you.
Clean install BTW.
coleypull15
11-03-2015 07:41 AM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
Coreyr384
07-10-2015 11:13 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Question about ISR mod on 3.0
