Pwr Door Lock Fuse?
Old 03-05-2004, 07:16 AM
turboale's Avatar
Pwr Door Lock Fuse?
Ok, here is the deal. A year a go when I sank my truck I fried the stock alarm system. Since then I had another alarm put in and the installer was afraid to hook up the pdl's as he didn't know if they were fried from the alarm going. At the time I was just excited to get my car back (they took FOR freaking EVER) Its been about a year now w/o pdl's now and its starting to piss me off. I WANT THEM BACK. Now that you know my life long story about my pdl's heres the real question. Is there any fuse/relay anything that isn't in the standard manual/fuse box that I could check to see if these bad boys work or not? I'm hoping its something simple like that. The reason why I'm thinking its that is the switch doesn't work either (and of course the alarm won't open them...) A new buddy of mine that runs a car audio place looked on an online installer site and it told him that its on a fused circuit. I have checked all the fuses in both boxes and all look gravy. Is there another place that I don't konw about that has the fuses? I'm stumped here... I'm not sure how they are hooked up but shouldn't the switch work w/o the alarm...
Thanks!
Old 03-05-2004, 08:04 AM
turboale's Avatar
I found the pdf file for the 96 and it says its located in the No.1 Fuse box with the relay (the one on the interior) but I don't see one on mine? Did they change it from 96 to 98? Or is it just hidden or something? Anybody...? Beuler? anybody? Cebby? SOS
Old 03-05-2004, 09:16 AM
Duffdog's Avatar
it should be on the back of the little white box ( fusebox ) i believe its labeled the integration relay---if not,, yer screwed. well, not really-- you could always have an installer wire up some relays for ya! but youll have to find a good experienced one thats been around a while.
T
Old 03-05-2004, 09:56 AM
turboale's Avatar
Ok, I'll look more in depth back there. Thanks bud!
edit:
Wait... on the back of the white box? How do you get back there?
Old 03-05-2004, 01:22 PM
Duffdog's Avatar
edit:
drop the whole lower dash--- five or six 10mm bolts, a couple screws. Then unscrew the fusebox and turn it around. one 10mm bolt you can see, the other is behind the subdash by the doorjamb. once both are out, you can turn the whole fusebox around and look for the integration relay ( it says "integration relay" right on it.
T
Old 03-05-2004, 01:30 PM
turboale's Avatar
Sweet, your the man! I'm going to wash the truck and then try and figure this darn thing out! Will I be albe to find the relay at a car parts place if it is the relay?
Old 03-05-2004, 02:50 PM
Duffdog's Avatar
thats a big negative--only available at dealer. youll know as soon as you take it out, it looks nothing like a normal relay--its got lots of funky circuitry on it.
T
westonian18
05-01-2020 06:38 AM
mussy01
12-13-2016 08:20 PM
theking11863
03-19-2016 09:36 PM
shisha1999
09-20-2015 11:44 AM
moonpie
07-31-2015 11:58 PM
Quick Reply: Pwr Door Lock Fuse?
