push button 4wd question
Old 03-25-2008, 06:59 AM
highmilesrunner's Avatar
in my old SR5, if i needed to take the console apart to change bulbs or whatever, i unscrewed the top of the 4wd button. now in my limited it has the pushbutton feature which the SR5 didn't. if i need to get behind the console area again, can i still just unscrew this too? i would think not since it has the pushbutton mechanism. just curious...
Old 03-25-2008, 08:12 AM
98runner210's Avatar
I believe there is a screw in the handle.
Old 03-25-2008, 08:29 AM
Rock Slide's Avatar
It can be removed in the same manner (one screw holding it on). I've removed mine a dozen times or more to access areas behind the dash.
Old 03-25-2008, 12:01 PM
so i take out a screw located somewhere on the handle/knob area then it screws right off?
Old 03-25-2008, 12:44 PM
Rock Slide's Avatar
yep, you got it.
The screw is located on the driver side of the shift knob. Unscrew it and you can slip the shifter right off the stalk.
Old 03-25-2008, 01:08 PM
sounds good. i appreciate it rock slide!
westonian18
05-01-2020 06:38 AM
jasonty
41
12-23-2018 01:00 PM
RustBucket
07-24-2015 04:46 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: push button 4wd question
