Problems with starting... stuttering - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-02-2007, 09:44 PM   #1 (permalink)
I have a 96 4Runner with almost 100K miles on it.
If I stop for a few minutes, say and run into the post office an need to start my engine again after only a few minutes I sometimes have a hard time getting the car started. It whirrs, then putters out. I have to stop and try this sometimes 4-5 times, occasionally waiting a few minutes between tries before it starts and stays running.
Is this a starter or alternator problem?
help!
kenfused is offline
Old 07-03-2007, 11:11 AM   #2 (permalink)
Mason Dixon's Avatar
Send a message via AIM to Mason Dixon
probably starter, the contacts get worn down, if your handy with the tools you can fix this yourself, better directions online through a search
__________________
http://www.sectalk.com/images/graphi...ds/alabama.gif
2000 4Runner SR5 4x4 Sport
Mason Dixon is offline
Old 07-03-2007, 11:18 AM   #3 (permalink)
netwt12's Avatar
if it's starting and then stalling out it's not the starter on alternator. i look into the mass airflow meter or the idle air control motor.
__________________
1985 X-cab pickup. stock
1988 Trail Truck. SAS, Dual Cases, FROR Twin stick, 30 Spline Longs & IFS Hub Gears, Exoed, Aluminum Trail-Ready Beadlocks, 37" IROKs, and Extreme Rock Rash.
2008 Camry LE.
netwt12 is offline
Old 07-04-2007, 11:28 AM   #4 (permalink)
111db's Avatar
Send a message via MSN to 111db
Quote:
x2. Start with mass airflow sensor.
Mine has done the same thing, cleaned the sensor and it helped. Actually its time to do it again...
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 07-05-2007, 10:34 PM   #5 (permalink)
Any writeups on how to do this?
Thanks!
kenfused is offline
Old 07-06-2007, 06:40 AM   #6 (permalink)
help!
From what you had described, it is not starter or alternator: I think the problem you have is related to IAC (idle air control) valve.
I would start by cleaning it.
progress4m is offline
Old 07-06-2007, 06:43 AM   #7 (permalink)
mkgarrison5's Avatar
anyway to clean it without tearing everything apart?? the way i clean mine is just take the plastic intake tube off the intake manifold and spray liberally on the butterfly valve wipe it fast and clean then spray into the "hole" below it and all in the intake manifold and put everything back on and crank it up and run it..
mkgarrison5 is offline
Old 07-18-2007, 10:11 PM   #8 (permalink)
Doesn't sound like your's is quite as bad as my buddy's, but his ended up being the fuel pump...long detailed painful troubleshooting to finally come to that conclusion.
Some threads about it:
http://forum.ih8mud.com/showthread.php?t=99905
http://forum.ih8mud.com/showthread.php?t=102573 (<--most helpful, shows the resolution, etc)
Good Luck...
mabrodis is offline
Old 08-05-2007, 02:07 PM   #9 (permalink)
HI everyone,
Finally got around to cleaning the mass airflow sensor.
Still has the issue.
If I stop the car, run to the post office for 3 minutes, then try to start up again, the engine dies. If I try to start it a few more times, it works.
Hmnnn
Looks Like I may have same issue as:
Does anyone have a write up to change the fuel pump?
Is this hard to do?
Thanks!
kenfused is offline
Tags
2000, 2005, airflow, camry, mass, meter, runner, startup, stuttering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
starting problems goohead 95.5-2004 Tacomas & 96-2002 4Runners 0 12-12-2006 09:23 AM
starting problems 97taco530 95.5-2004 Tacomas & 96-2002 4Runners 5 09-30-2006 08:09 PM
Starting problems.... joshik 95.5-2004 Tacomas & 96-2002 4Runners 4 08-20-2004 09:09 PM
starting problems? grafix43 95.5-2004 Tacomas & 96-2002 4Runners 8 02-11-2004 12:11 AM
starting problems thowho1985 95.5-2004 Tacomas & 96-2002 4Runners 4 08-06-2003 07:38 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
