Problem after tune up
Just did a tune up on my 1993 4Runner 3.0 and immediately after I started the vehicle, I noticed that the idle was abit rough. It will idle very low, around 500 rpm until i hit the gas, then it stabilizes around 900 rpm. I was carefull not to throw the gap on the plugs out when installing them so that shouldn't be a factor. Im not to familiar with the Toyota electronics but is it possible that the ECU is just readjusting to its new state of tune as the plugs and distributor cap and rotor were on their last legs. If not i guess i better recheck the gaps.
It sounds like a cylinder isn't firing. Pull wires until the idle doesn't change. That's where your problem is. It could be a plug, bad wire, or the distributor cap.
Good Luck
Good Luck
Good Luck
Good Luck
06-01-2021 01:51 PM
