Problem with 4WD and A.D.D Controls
Old 05-01-2006, 05:13 AM
Bratik's Avatar
I am having problem with engaging/disengaging 4WD system.
I have a Limited 2000 4Runner that has push in button on the 4wd selector stick. When I pressed it, the lights on the dash that shows 4wd system engaged are blinking. Unlocking the button or moving lever to 4wd or 2wd position
are not doing anything. Now I am half way into 4wd. I feel that the front wheels have engaged into 4wd mode, where I currently stuck. Please help me resolve this issue before EC4RJ event in 2 weeks.
Old 05-01-2006, 07:13 AM
tour4fun's Avatar
I had the same problem awhile ago. BruceTS helped me troubleshoot. It was a problem with the vacuum going to the solenoids. Thanks Bruce
Old 05-01-2006, 07:16 AM
Bratik's Avatar
This is exactly what I was thinking.
Bruce, can you help me with some diagnostic.
Thanks,
Old 05-01-2006, 08:24 AM
eric-the-red's Avatar
Try this, it might help
http://www.off-road.com/toyota/tech/add/
Old 05-01-2006, 05:27 PM
BruceTS's Avatar
There may be nothing wrong at all, go offroad and put it in 4WD low range and drive it around a bit, sometimes things get a bit sticky if the system hasn't been used. As for explaining exactly what may cause your problems, that would take quite a bit of explaining, since your system is quite a bit different than the link provided from another member. Not only do you have a standard ADD system, but a center diff lock as well and they are both interconnected. If you can get a Factory manual, there is a good trouble shooting guide on the system.
Old 05-02-2006, 05:25 AM
Bratik's Avatar
Thanks Bruce.
Old 05-02-2006, 12:47 PM
4RUNN!N's Avatar
Try reversing and engaging 4WD. It worked for me when my ADD wasn't working. It's been working fine for about 5 months now.
Old 05-02-2006, 05:42 PM
dragr1's Avatar
Bratik-wish I could help, see you at SE4RJ! Don't forget the Russian cookies!
Old 05-03-2006, 03:52 AM
Bratik's Avatar
Thanks for reminding me about it. I'll put them on my list.
See you there.
coryc85
09-09-2015 06:24 AM
adammtb
07-27-2015 11:57 AM
rushw
07-18-2015 01:46 PM
TokyoD23
07-12-2015 06:01 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: Problem with 4WD and A.D.D Controls
