Probably an Easy Question..
Old 07-22-2011, 01:51 PM
smokey0066's Avatar
I'm getting ready to do the radiator replacement for fear of the strawberry milkshake after reading so many stories. My question is how do you take off the coolant reservoir to clean it out? mine has some gunk in there that I'd like to rinse/wash out while I'm flushing and doing the swap.
Old 07-22-2011, 01:58 PM
SCToy's Avatar
Unbolt it and wash it out. I just filled mine with rocks and baking soda and shook it a lot. Rinsed it several times and put it back on. Seemed to work.
Old 07-22-2011, 02:00 PM
smokey0066's Avatar
where is the bolt. that is my question. It looks like it just floats there between the top rad support and battery.
Old 07-22-2011, 02:07 PM
SCToy's Avatar
Picture?
Old 07-22-2011, 07:39 PM
sleeper2002's Avatar
Mine slides onto a rail and just hangs there. I've cleaned mine out before with some Simple Green and a whol lot of rinsing and it worked great.
Old 07-22-2011, 09:20 PM
smokey0066's Avatar
Well I did see some black thing on the front side but I probably didnt try pulling up hard enough to break it free. I shall try again. Seriously I was feeling all around for a bolt/bracket and was kind of mystified on how that thing is retained.
Old 07-22-2011, 10:02 PM
quicksilvr's Avatar
Just pull straight up on the reservoir. The reservoir is formed to slide down onto a fixed bracket.
punks_is_4x4
02-26-2016 04:29 PM
kbpickens
10-02-2015 03:37 PM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Probably an Easy Question..
