power steering belt tensioner
Old 12-14-2008, 01:59 PM
kev7706's Avatar
I'm in the process of changing drive belts on a 3.4. On the power steering belt, I have loosened the lock nut for the tensioner. However the tensioner bolt is giving me problems. I have located it and tried to get a wrench on it, but a pipe is in the way. Do I need to remove this, or am I just approaching the bolt from the wrong angle? I can post a picture if needed.
Old 12-14-2008, 02:26 PM
GSGALLANT's Avatar
You shouldn't have to remove anything to get to it. However, it is the worse one of the three to do. A ratcheting wrench might help you some, but it will still take a bit of time to do, because you can only turn it a little bit at a time.
Old 12-14-2008, 03:20 PM
Yukon's Avatar
Get a 14 mil ratcheting wrench. You need it. Besides that, i took off a wire to the power steering pmp to make it a bit easier, but nothing else.
Old 12-14-2008, 04:13 PM
kev7706's Avatar
hmmm
I checked under the hood of my brother's Taco with the same motor and the bolt is easy enough to access. Mine is different though. Let me take a pic.
keithporter83
07-24-2015 07:37 AM
yoterr
07-24-2015 04:29 AM
whereAreMyPants
07-22-2015 03:32 AM
PlayAwhile
07-20-2015 11:36 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: power steering belt tensioner
