Power Stearing leaks when engine if off?
Old 09-20-2009, 09:33 AM
xcmountain80's Avatar
Ok to the best of my knowledge you shouldn't turn the wheels with the engine off but you can if you really need to..... I had the front on jack stands ghetto painting my brake calipers and noticed a squoosh noise when turning the wheel in order to access the other side of the caliper. I noticed fluid flowing down the leg of the jack stand and then popped the hood to find out it was coming out of the PS reservoir or a line near by since it was just me I couldn't turn the wheel and look for the leak. Any ideas?
A
Old 09-20-2009, 05:07 PM
BajaRunner's Avatar
looks like its coming from the cap? maybe it needs to be replaced? Is it doing it when you turn the engine on? Too much fluid>??
Old 09-20-2009, 08:33 PM
CYi5's Avatar
Painting your calipers Aaron? At least I can see they're black. Every 3rd gen toyota I've seen leaks from the cap of the power steering reservoir. I haven't seen any actually dripping to the ground though, so I guess i'd check/possible replace the cap.
Old 09-21-2009, 05:17 AM
Ok ok the calipers were rusting a bit after the big brake upgrade and the filing I did to them for wheel fitment. Soooo paint them and no more rust, I'm not a blinger. Yes the cap leaks or sprays when the truck is off but not when it is on, I did also get a weird ka-thunk noise with the truck off and cycling the steering wheel. Note I was turning the wheel extremely fast and very aggressively, under normal just turn to the left and then back right I heard a leaking noise but no fluid.
A
06-01-2021 01:51 PM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
God's Bounty Hunter
07-08-2015 12:54 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Power Stearing leaks when engine if off?
