Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Power difference between 2" and 2.25" exhaust
__________________
-Anthony 1987 4x4 Carbureted 22R truck-Daily Driver 1988 4x2 Carbureted 22R truck-Current Project Truck |
#2 (permalink) |
Vendor
Sales Rating: (0)
i have a freeflowing catco cat on my truck never knew what it was like stock..im sure it helps out... i have 2.25" piping on mine.... my trucks a 4x2 85 22r
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Has anyone ever driven a truck with a 2" exhaust and compared it to a 2.25"?
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Anyone ever done anything like that?
__________________
#6 (permalink) |
Guest
Personal
Sales Rating: (0)
I have the 2.25 on mine with a magnaflow cat and proflo muffler and running back out into 2.25. its sweet. you will like it better. more flow and rumble.
errrr edit....uh I didnt look to see what kinda rig you were working with until after i posted. 22r and huge exh will kill you imo. 225 may be to big but i have never had a 22r. I have the v6. So I hope you find the info you really need. surprised more members have not replied to help you out. Last edited by Yoter; 01-04-2005 at 12:41 AM. |
#7 (permalink) |
Vendor
Sales Rating: (0)
my friend had a stock 84 22r and his truck was a lot slower than mine.. his also 4x2 std cab shortbed... eh had smaller tires too....
#8 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
__________________
#9 (permalink) |
Vendor
Sales Rating: (0)
yup my trucks got a carb.... i have an intake mod done as well.... its really just a bigger filter but it does help out a good amount... my trucks a 4x2, and they are from what i have heard a lot quicker then the 4x4.... his tires were 30x9.5s and my tires were 31x10.5s i have 3.08 gears with a 5 speed stick though.. he had a 5 speed but i didnt know what gears he had in his truck...
#10 (permalink) |
Vendor
Sales Rating: (0)
http://www.explorerforum.com/data/sh...y.php?cat=3367 is the gallery housing my intake pics....
#11 (permalink) |
Personal
Sales Rating: (1)
Check in with members deathrunner and crazydiamond. I believe they both have 2.5" exhausts and differing opinions on the results. Depends on what you want to do. My understanding is that too big (ie the 2.5") kills low end torque but is good in the upper speed ranges. Therefore good on hwy but not so good for slow wheeling. I've also gotten the impression that 2.25" gives a reasonable bump in power and helps low end torque a bit. There are plenty of threads about this if you do a search with opinions ranging from "huge increase in performance" to "didn't do much". The only real agreement I've seen is that they all "sound cool". I'm interested in ths mod as well but fortunately it is low on the priority list so I have time to learn more about it. Good luck.
Mike
__________________
1997 4Runner Limited 3.4, AT, E-Locker |
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
I usually keep my RPMs down, so I will probably just stay with 2", but I was thinking about doing that intake mod. Does it lower gas mileage at all?
__________________
#13 (permalink) |
Sponsoring Member
Vendor
Sales Rating: (0)
This site has some pretty good info on sizing exhaust:
http://www.torquetechexh.com/whichsize.htm The short form is this graphic: ![]() 2.25" would be too large for the 22r.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for the chart. 2" almost seems to large. I just measured my tailpipe and it appears to be 1.75" in diameter. If I upgrade to 2" from the cat back, do I need to do something to the collector in front of the cat to make a difference?
__________________
#15 (permalink) |
Personal
Sales Rating: (0)
I recently put on a 2.25" catback exhaust on my truck and I didnt noticed a decrease in low end at all. Really the only thing it did was give it a kick around 3500rpms and up. You will be fine running 2.25" tubing.
__________________
92 pickup... sold 90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up 79 2wd yota pickup |
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for the information. If I upgrade the pipe diameter, will I need to do something with the collector in front of the cat to see a difference?
__________________
#17 (permalink) |
Personal
Sales Rating: (0)
2.5 in exhaust works great..
__________________
TRD Supercharger,TRD 7th injector,URD AIC ,Headers,2.5 Magnaflow exhaust,Airfilter,air box mod,flexalite 210 fans,optima yellow top,Warbro 190 ,TRD t stat,ramsey 8000 winch,Marlin Crawler Clutch and rear locker mod |
#18 (permalink) |
Personal
Sales Rating: (0)
You should see a big improvement in power with the new cat and 2.25 exhaust, It made a big difference on my 86 4runner, adding a header made even more power. You might want to do the air filter mod also. My 4runner is a 22RE but I did the mod on my 90 two wheel drive truck and it made a big difference when I step on it. The only difference in milage is the fact that I always have my foot in it since it's more fun to drive now...
#19 (permalink) |
Personal
Sales Rating: (0)
Supernerd never got an answer to his question, and I'd like to know too. If I go with a 2.25" catback exhaust, I'm assuming that "catback" is meaning that the diameter of the cat is 2.25" too. In other words, the increase in tubing size happens right before the cat... Correct? So, as supernerd asked, does anything have to be done to the collector or downpipe in front of the cat? What benefits, if any, would come from increasing the size of the downpipe?
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's {REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop |
#20 (permalink) |
Personal
Sales Rating: (0)
Run the 2.25" exhaust pipe. I have a 2.25" exhaust, high-flow cat and a Dynomax "Super Turbo" muffler on mine. I've noticed no decrease in TQ with the 2.25" compared to the stock pipe. In fact, the low-end TQ increased with the 2.25" exhaust. However, I wouldn't go to a 2.5" pipe, you may lose some TQ with that. The 2.25" will be fine.
I also have the tri-Y Thorley header as well. Highly recommended with the 2.25" exhaust! It'd be like a whole new truck with the header and exhaust. Trust me! You'll really notice the difference going up freeway on-ramps and moderate to steep hills. A poor mans dyno if you will. I never liked steep hills or freeway on-ramps with the stock exhaust and manifold. With the header and exhaust, the truck loves these inclines now. It just keeps on pulling and pulling until I get near redline.
__________________
'88 Toyota PU Classic White 4x2 std. cab 22R 4sp. 400k+ original miles Mods: DT header/ FAL 165 /180* stat/ 2.25" catback/ Super Turbo muffler/ V-power NGK's/ CAI/ K&N/ 4x4 valence/ Hella H4 85w-100w/ 10-gauge harness/ SR5 cluster/ digital clock/ intermittent wipers/ glovebox light/ dual horns/ marine grade carpet/ cloth bench seat/ '94 sunvisors/ SR5 rear trim panel/ day-night rearview mirror/ chrome shifter knob/ 20% tint/ bilsteins Coming: V6 brakes/ drilled rotors/ 3.5" lift. |
| Tags |
| 2, 225, 22re, 25, 250, 4x4, ca, diameter, difference, exaust, exhaust, hill, performance, power, steep |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Show me your lift! I wanna see the difference in lifts 1.5",2",3"4" | NG Crawler | 95.5-2004 Tacomas & 96-2002 4Runners | 45 | 10-12-2012 11:46 AM |
| Difference in gas mileage between 30" and 31" tires? | dave1993 | 86-95 Trucks & 4Runners | 2 | 09-24-2006 08:40 AM |
| 3.0L: 2.25" Mandrel bend vs. 2.5" Crush bent? | Randomness | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 09-29-2005 11:04 AM |
| Does gas "Brand" really make a difference? | Beartracker | Off Topic Talk | 36 | 07-27-2005 06:39 PM |
