Power Antenna Toggle?
Has anyone installed a toggle switch to their power antenna to control it going up and down? My antenna's not broken yet so I don't plan on doing a whip mod anytime soon, but I would like to install a toggle to move it up and down when I need it.
I read the whip mod from: http://www.4runners.org/writeups/whip/index.html and saw the diagram of the antenna to the back of the deck. But wouldn't I need to splice the toggle into the wire that leads to the relay switch behind the front dash panel? That's the one that I hear "click" a few seconds after shutting the engine off.
You'll find the search feature quite useful on Yotatech. For example...
Search: antenna
https://www.yotatech.com/forums/show...hlight=antenna
Search: antenna
Power Antenna black/white + at radio
there are different ways of doing it but this is the simplest way.
cut the wire and use a switch to power the wire that leads to the relay module.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
delmert
09-30-2015 04:34 PM
