Power Antenna - Stuck Up and No Motor Sound and other Antenna Questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-28-2004, 08:53 AM   #1 (permalink)
PhxRunner's Avatar
I've searched the forum for the last two days and I haven't found the symptom I'm seeing.
Q1 - My power antenna on my 2001 Ltd is stuck in the up position. When I turn the car off or when I change from FM to CD, I hear nothing from the power antenna motor. The Chilton's manual says that often the relay fails before the motor. I'd like to check the relay, but I don't know where to find it. Where is the power antenna relay located?
Q2 - The Chilton's manual also says that in order to extend the antenna fully, press a couple of buttons simultaneously have a "helper" guide the antenna out. My problem is I've replaced my stock radio with an aftermarket one. Do I need to get my stock out of storage in order to change the antenna mast?
Q3 - The stock radio has 2 antenna connections (1 fat and 1 thin) and there are 2 antenna wires. My aftermarket stereo has one connection. Only one of the antenna connections fit (the fat one). I have had to tuck the thin antenna wire back into the dash. What is the purpose of this wire? Is there a way to add this thin antenna wire into the mix?
FYI...I don't want a fixed mast solution. I'm looking to get my power antenna fixed.
Thanks in advance.
__________________
2001 Titanium Limited
Nakamichi 45Z - PPI 60x4 Amp - Alpine DDDrive 6.5" Comps
JL Audio Steathbox - Delphi XM Radio - Sylvania Silverstars
PhxRunner is offline
Old 06-28-2004, 10:20 AM   #2 (permalink)
Jboy's Avatar
That plastic chain type thing broke. Mine did the same, I hate power antennas. Anyway, there is a section here to do the Tacoma whip swap otherwise you`ll have to replace your antenna assy.
__________________
2000 4Runner
2" lift, not Frankenstruts, OME 906 rear springs/OME shocks
MT/R 285/75R16 on AR Atlas 16x8
Offroad Solutions Manual Hubs kit
Jboy is offline
Old 06-28-2004, 10:24 AM   #3 (permalink)
TDiddy's Avatar
Send a message via AIM to TDiddy Send a message via Yahoo to TDiddy
If the antenna motor was running but there was no movement, then I'd agree that a new mast was needed, but the motor isn't running according to the post.
I don't know where the relay is offhand, but maybe someone else will. You don't need your stock stereo to change the antenna mast, if in fact that's what you need to do. Just do a search on here, there's lots of posts on how to change it.
TDiddy is offline
Old 06-28-2004, 03:37 PM   #4 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Tear that thing out and do the fixed mast antenna mod.. If you fix it now you'll buying another one eventually and then another....... I know guys that went through 3 of them. There's a write up and parts numbers in the tech section cost about $30 or so if that.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Tags
02, 2002, 4runner, antenna, auto, car, change, display, fixing, motor, power, radio, solutions, sound, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Antenna stuck ( bent ) crbocaj125 95.5-2004 Tacomas & 96-2002 4Runners 11 03-24-2007 01:53 PM
Couple of CB questions RE: Power source & antenna cackalak han GPS & Communication 1 08-31-2006 11:04 AM
Power Antenna Mast- how to get to the antenna assembly xxspokan 95.5-2004 Tacomas & 96-2002 4Runners 8 02-18-2006 06:08 PM
4Runner Power antenna questions kenfused 95.5-2004 Tacomas & 96-2002 4Runners 14 01-05-2005 10:22 AM
Who has a power antenna motor to sell/give me? PhxRunner 95.5-2004 Tacomas & 96-2002 4Runners 0 06-29-2004 04:01 PM
2009 InternetBrands, Inc.
