powdercoating aluminum 3rd gen wheels
Old 07-20-2009, 04:46 AM
sharrack's Avatar
What do they do to remove the clearcoat off of the rims?
Mine is chipping off and I'd like to have therims done in Satin black.
Any other advice on the finish?
Flat...gloss...satin?
Thanks ,kenny S
Old 07-20-2009, 05:18 AM
bgmac's Avatar
They will first be sandblasted. I always liked semi-gloss.
Old 08-03-2009, 08:18 PM
Ron Helmuth's Avatar
I could be wrong but powder coating does not stick to aluminum quite like steel....perhaps after the sand blasting....
Old 08-03-2009, 09:29 PM
GoFaSSter's Avatar
We powdercoat aluminum all day long at work. As a matter of fact that is all we powdercoat. As long as the core temps are correct it should not be a huge problem. The advantage to paint (especially on wheels) is it can be touched up a lot easier.
Old 08-04-2009, 06:15 AM
Jay204's Avatar
powdercoating is the way to go...my wheels and bumper are done.
Old 08-04-2009, 07:05 AM
4ever4running's Avatar
Something you might want to look into is painting your weels rather than powdercoating. I still have my stock wheels and I am going to paint them as soon as I get a chance because powdercoating is too expensive for my college budget. Dulpicolor has everything you need to prep, prime, sand, paint, and clearcoat (if you want) your wheels all for a lot less than powdercoating. Its a pretty easy project to do on a weekend and it is a lot easier to touch up if it gets scratched or dinged
Old 08-04-2009, 07:42 PM
thanks for the info Go Fasster I stand corrected and appreciate the knowledge.
Old 08-04-2009, 07:52 PM
waskillywabbit's Avatar
You can powder coat just about anything metallic that will take the curing heat.
Powder coating wheels is a PITA because of all the nooks and crannies and the amount of voltage needed to pull in the powder.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
93toyoguy
08-02-2015 07:41 PM
94yotaMI
07-21-2015 05:47 AM
Quick Reply: powdercoating aluminum 3rd gen wheels
