Possible blown headgasket on my 94 yote pickup?
Hello all this is my first post, I have been having a few problems with my 94 pickup. About a week or so ago my truck started idleing eratically and and blowing tons of steam out of the exhaust. Today the steam has gotten worse the ideling just gos up and down and up and down and smells of anti freeze really bad. It shakes really bad upon cold start-up (I live in Wisconsin) anybody have any ideas? I should would appreaciate anyones input. Thanks
Check your oil. If it looks like chocolate milk, then you definitly are mixing oil and water.
What motor is in your truck? If it is the 3.0 has the Head Gasket ever been changed under the Toyota campain?
1 Post
I had no signs mine needed a head gasket replacement until I looked under the valve cover and saw 'yuck'. Other than my vehicle was losing coolant, no signs existed. One determining factor was when I did a leak down test. That was a guarentee that my gasket was shot. Since I replaced the head gasket, all is well now. G/L.
Sounds like a blown head gasket. Take the oil filler cap off and look under the cap. See if it's chocolate. Also look at the coolant in the radaitor to see what it looks like. Have you been adding coolant?
Keep us posted what you find out.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
