Is it possible !
Is it possible !
could the source of my rattle be a loose antenae motor in my front fender?? Has any one had this problem ? Is there a way to tighten things up Im running out of possible sources:cry:
Does it rattle when you shut your door? I know I hear a rattle on mine from the right front fender area when I shut my door. It use to be annoying but I'm use to it now.
It is right behind the inner fender, I doubt you even have to take the tire off...probably a couple phillips or 10mm's and it'll fold right out of the way and you can give it a quick grab to see if its loose...worth a try IMO.
I know this would not be too difficult to check out but the wheel well is held on with kind of a clip that are supposed to be a pita. I just thought if no one else had ever experienced a loose motor mech. I would move this down my list of things to check out. thanks for all input. :confused:
