Porting and polishing Heads.
Old 03-03-2010, 01:24 PM
mitfan311's Avatar
I havent heard a lot about the performance possibilities that could come with porting and polishing the heads or intake of the 3.0. I noticed that there seemed to be a good amount of metal that could be ground away between the two. Im not really looking to do this at all on my 95 4runner. But I did do it to my 1984 Nissan 300zx Turbo. I pull a little over 320 hp out of mine. But i wonder as im not an expert on the toyota 3.0 if there would be much to gain without a turbo. Most of the mods for a non turbo Nissan 3.0 are minimal. There is always something to be gained when the air flow is less restricted but I dont know what the tolerance levels of these heads are. Would it be likely that grinding away any extra metal will damage theses heads?
Old 03-03-2010, 01:45 PM
90runnerfan's Avatar
theres a problem when you over flow the heads ive seen from doin harleys before and if that happens your pretty much screwed. companys spend lots and lots of money in to r&d of performance heads, would i give it a shot heck yea but i wouldnt remove much just a little massage to work them nicely but only if i were doin a rebuild at the same time too much work for so little improvement.
kawazx636
10-06-2021 03:03 PM
LittleUgly
15
01-02-2020 01:30 PM
alexcarey
10-14-2015 06:05 PM
sonorn67
09-19-2015 05:39 PM
old87yota
09-09-2015 12:39 PM
Quick Reply: Porting and polishing Heads.
