| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Poor Mans Quick Disconnects
__________________
Eric 2001 4Runner with stuff: http://www.ultimateyota.com/index.ph...6&topic=1098.0 Last edited by ecchamberlin; 12-18-2005 at 10:38 AM. |
#2 (permalink) |
Careful on the turns with those because I have seen people break sway bar links just taking hard turns on the road. When you drill a hole through the center, you are making it that much weaker. If you take it easy on the turns they should be fine.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 12-19-2005 at 05:46 AM. |
#3 (permalink) | |
I saw Localmotion snap an new OEM link just driving down a trail. Great idea, but wabbit's discos are cheap andstrong
__________________
Eric 88 4runner Quote:
#4 (permalink) |
Between trail outings I am putting the nuts back on and the holes are drilled out far enough so that the rubber washer fits in between which also allows the nut to be tightened beyond the holes I drilled it the bolts. I will keep an eye on them because that is also a concern I have. I think that the biggest reason for the breakage of the link is over tightening them and then hanging a wheel. The sway bar is basically holding the weight of the hung wheel's suspension (a-arms,coil over, wheel/tire +) and if that bolt is really tight it snaps. My $.02
I like WabFab's disco's but they are not tool-less. I think that is the whole idea behind quick discos. If I have to get out tools I may as well take off the lower nut also. If these break ( and they probably will ) I wil buy a set from him because I think he has the best design out there followed cloesly by 4crawler's. I only have $4 in these so nothing to loose.
__________________
Eric 2001 4Runner with stuff: http://www.ultimateyota.com/index.ph...6&topic=1098.0 |
#5 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Quote:
Mine will still be for sale...when you come to your senses. ![]()
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale Last edited by waskillywabbit; 12-19-2005 at 04:58 PM. |
#6 (permalink) | |
Staff
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#7 (permalink) | |
Quote:
Just thought I'd give it a shot. I like messing around in the garage. This was the first time wheelin without the sway bars and I was shocked at how much better the front did. Is there a noticable benefit from unbolting the rear sway bar? That one seems even easier to unhook. ![]()
__________________
#8 (permalink) | |
Quote:
__________________
CJ ...<>< 03 DC TRD Tacoma 4wd with a bunch of junk. SOLD 1964 Chevy Biscayne, 230 I6, lowered, satin black, old-school legit. Just wheel the stupid thing!!! But do it responsibly, ok? My band: Road Worn Saints |
#9 (permalink) |
Yup that is Marc's That pic is at Corral Canyon a few weekends ago.
__________________
#10 (permalink) |
yep..i snapped a OME disco and lost my bushings.
Wabbits are cheap(realively) and are durable. And plus, he told me if i ever have a problem , he would give me his rig
#11 (permalink) | |
Quote:
Hmmm... Wabbit said that? I think he had been hovering over the grinder a little too long that day....
__________________
#12 (permalink) | ||
Quote:
__________________
#13 (permalink) | |
Staff
Quote:
__________________
#14 (permalink) | |
Quote:
Naw, Brian, I think that was your wife yelling over the noise of the grinder... Have a good one!
__________________
| Tags |
| bar, chevy, disconnect, disconnects, make, making, quick, sway, swaybar, trucks |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Poor mans selectable front locker... idea atleast | Mr. Bob | 95.5-2004 Tacomas & 96-2002 4Runners | 34 | 12-07-2006 06:24 PM |
| Poor Mans Air Locker | trx125 | 86-95 Trucks & 4Runners | 20 | 05-21-2006 09:26 PM |
| Quick Disconnects? | Stump1883 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-04-2005 01:23 PM |
| Quick question on quick disconnects... | WSU4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-25-2004 07:27 AM |
