Pond Liner GapGaurds...
Old 01-30-2006, 09:47 AM
2wheelBLACKOUT's Avatar
I just picked up some pond liner to cover up my BL Gaps in the rear, How are you guys attaching this stuff? zip ties? I was thinking of getting the Plastic push clips from the dealership and drilling holes and using the clips. how does that sound? b4 i start anything i would like to know what other options you guys are using. any pictures and info will be great. thanks.
Old 01-30-2006, 01:45 PM
hmm, I guess no body has ever done this.
Old 01-30-2006, 01:52 PM
Bob_98SR5's Avatar
i believe calrockx has. check his website or pm him
Old 01-30-2006, 02:10 PM
Mr. Bob's Avatar
I used push clips on the last few BLs I did... I got them from my local parts store, way way cheaper than the dealer was....
Old 01-30-2006, 06:03 PM
photoleif's Avatar
i used heavy black rubber/plastic runner from home depot, and bolted it on with washers to distribute the stress. in front i used the existing snap-ins.
Old 01-30-2006, 07:11 PM
JHupp's Avatar
I have seen it done with the plastic push clips Mr. Bob was talking about it. You have to drill a very small hole through the line and frame, a little smaller then the clip, and then just push it in. The guy I went with on the last TTORA ride did that, and he said it holds up extremely well, probably your best bet.
Old 01-30-2006, 08:32 PM
BajaRunner's Avatar
I got the thick black rubber crap but basically the same thing I guess?
Anyways, I just used some self tapping metal screws and screwed it on to the inside fender well.
Old 01-30-2006, 08:53 PM
grimpy's Avatar
I picked up the rubber pond liner by Firestone iirc from Home Depot... Ended up just using self tap screws... I do plan on taking them off and using regular plastic clips sometime though.
Old 01-30-2006, 09:07 PM
calrockx's Avatar
yep, i used the push clips. orderd them from some fastener website. drilled some holes, popped em in, done and done.
terminator
10-13-2021 10:13 AM
A2theK
09-30-2016 12:50 PM
87SR5justin
09-29-2015 02:50 PM
ViperTT
08-14-2015 05:27 AM
Quick Reply: Pond Liner GapGaurds...
