polishing wheels - YotaTech Forums
Go Back   >
polishing wheels
LinkBack Thread Tools Search this Thread
Old 03-21-2007, 06:46 PM   #1
polishing wheels
I picked up a set of limited wheels today to replace my sr5 ones with the flaking clear coat. The new wheels are spotty and the glare changes on the spots......didn't looks so bad in his dark garage! Any ways to help them or is it stuck that way? thought that getting them powdercoated black but that may be mucha $$.
kenai is offline   Reply With Quote
Old 03-21-2007, 07:05 PM   #2
lftd_86_yota's Avatar
I spose if you polished hard enough with steel wool and some wicked polish you could take the clear coat off unifromly and it wouldn't look too bad, would produce an amazing shine, but when the light hits is jut right it'll shine a little I had to go this route on my b2200
lftd_86_yota is offline   Reply With Quote
Old 03-21-2007, 07:39 PM   #3
pattycakes77's Avatar
the clear on my wheels was coming off so i stripped it all off with some "aircraft coating remover" in an spray can. i found it at a paint shop or at the autozone too. it's nasty stuff so don't get it on your skin, breathe it in, or get it on any painted or plastic surface you don't want ruined. took the clear off really well. once i got it all off i used a product calle Wenol, an electric drill, and a cotton wheel to polish the aluminum. one problem though, if you don't re-clear with something good, the shine won't last unless you keep polishing. i used some very mild cleaner and soap on my wheels afterwards and it dulled and streaked them. i would suggest not using duplicolor clear, didn't work for me. i did like the POR 15 clearcoat product though, hard as nails but a bit hard to get a nice coat on unless you have a paint gun/sprayer.
that's my $.02, good luck
patrick
pattycakes77 is offline   Reply With Quote
Old 03-21-2007, 09:24 PM   #4
thanks, i may give that a shot with my old wheels first to see how it works out. Are the limited wheels clear coated also? thanks!
Old 03-21-2007, 09:32 PM   #5
1989toy4wd's Avatar
Its not that hard to paint rims...and its easy touchups and cheap too I spent like 30 bucks for all 4 wheels!! there is a good right up on here, look under there for painted wheels!! take a look at mine on my sig...(they were dirty in that pic...lol)
1989toy4wd is offline   Reply With Quote
Old 03-21-2007, 09:33 PM   #6
1989toy4wd's Avatar
BTW i used duplicolor high heat for everything primer, paint, and clear!! FWIW
Old 03-21-2007, 10:06 PM   #7
Nic
Nic's Avatar
This is basically how I removed the clear coat on mine:
http://home.off-road.com/~kemanuel/S...l/SR5Wheel.htm
Nic is offline   Reply With Quote
The Rebuild of Lucy. 1982 4X2 Standard Pickup jasonty Pre 84 Trucks (Build-Up Section) 38 10-05-2016 03:17 PM
what happened Dakotaneu 86-95 Trucks & 4Runners 4 08-15-2015 08:24 AM
How to measure valve lashes without knowing their original order? foampile 03+ 4Runner/GX470, & 05+ Tacomas 0 08-11-2015 01:41 PM
steering wheel off center; centered by rotating tires Up&Down 95.5-2004 Tacomas & 96-2002 4Runners 8 08-05-2015 07:20 AM
Help me for the love of god!!!! Dakotaneu 86-95 Trucks & 4Runners 3 07-27-2015 01:03 AM
Tags
aluminum, pickup, polishing, sr5, toyota, wheels, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
