Po171 code.. again... reposted from mantenance - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-06-2003, 01:29 PM   #1 (permalink)
well, this all started in feb. here's the original thread. http://www.yotatech.com/showthread....highlight=p0171
synopsis: got the 171 code bank 1, changed the upstream 02 sensor, got a 171 code again bank2, changed the downstream 02 sensor, got 171 code again with both bank one and bank two showing. i had the injectors cleaned by the local mechanic. it wasn't the ultrasonic clean, but the snap on motor vac. i can tell a difference, the motor is more responsive, better pickup and accerlation, HOWEVER, the infectios, small pox ridden 171 code came up again. bank one lean.
what next?...... did i get a bad new sensor? or is there something else i'm missing? i've searched the forum pretty heavily so i hope i'm not asking any questions that have already been answered.
thanx
brad
bamayote is offline
Old 06-06-2003, 01:37 PM   #2 (permalink)
Away
Dr. Zhivago's Avatar
Send a message via ICQ to Dr. Zhivago Send a message via AIM to Dr. Zhivago
The link you provided does not work...
So, I'm assuming that no one told you to clean the MAF Sensor. Also, check for vacuum leaks. I don't know what year you have, but I can guess that it is a 3rd Gen.
Cleaning the MAF on a 99-02 is a really simple procedure, and not so much on a 96-98.
Look into having the MAF cleaned or replaced and triple check for vacuum leaks. Even the smallest ones can cause this problem.
Hope this helps.
Dr. Z
Dr. Zhivago is offline
Old 06-06-2003, 04:33 PM   #3 (permalink)
yeah dr z
i cleaned the maf (which made a big difference in performance).
checked for vac leaks till i'm blue.......lol
and i may just replace the maf this time and see if that works.
i was just looking for any other ideas. i've pretty much been down the list as far as the usual culprits that i've read about on yotatech.
lemme see if i can get another link.......thanx for the reply dr z. you were most helpful when this first came up.
http://www.yotatech.com/showthread.p...ighlight=po171
bamayote is offline
Old 06-08-2003, 10:55 AM   #4 (permalink)
any ideas?
did the link work this time?
bamayote is offline
Old 06-08-2003, 11:21 AM   #5 (permalink)
FattyCBR's Avatar
Has your throttle body ever been removed? It's possible to put the gasket between the TB and plenum in backwards, which can cause a vacuum leak/problem. I'd say if you still have the code after replacing both O2 sensors than you definitely have a vacuum leak.
__________________
Milan
_ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3, SM465, D20 <- Sold
FattyCBR is offline
Old 06-08-2003, 01:55 PM   #6 (permalink)
thanx fatty
never thought i'd ever say.......'thanx fatty".
thanx for the reply....i'll go over it again. and no the throttle body has never been removed. and it idles fine........it idles around 6-700rpm.
cya
brad
bamayote is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
My check engine light is on (Code DTC PO171) pfbmgd 95.5-2004 Tacomas & 96-2002 4Runners 13 07-14-2009 11:56 AM
PO171-1999 4runner JEDI87 95.5-2004 Tacomas & 96-2002 4Runners 13 06-21-2007 08:29 PM
PO171 System Lean Bank 1 Code for a 00 Toyota Corolla amit007 Off Topic Talk 8 11-04-2006 04:14 PM
another PO171 code... ebelen1 95.5-2004 Tacomas & 96-2002 4Runners 34 10-02-2006 08:11 AM
PO171 code mhawker 95.5-2004 Tacomas & 96-2002 4Runners 4 11-11-2002 12:22 PM
2009 InternetBrands, Inc.
