Plowed through mud, now my A/C compressor squeels when A/C turned on - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-13-2007, 10:37 AM   #1 (permalink)
RR DIFF LOCK's Avatar
Did a lot of playing in the mud over the weekend. Usually I avoid mud because it's such a mess to clean afterwards, but I caved to the peer pressure I've carefully cleaned the easily accessible portions of the engine bay and hosed down the belts pretty extensively, but I'm still getting a LOUD squeal when I engage my air conditioning. Sounds like when you hear a car with a squeeky accessory belt under the hood, but it's only when I turn the A/C on. Any suggestions? Are any of the A/C parts able to be pulled and disassembled for cleaning, without purging freon into the atmosphere or incurring costly repairs at the dealership?
__________________
Scott - Gilbert, AZ
'97 TOYOTA 4Runner Limited 4WD, 3.4L V6 with A/T, Factory Electronic Locking Rear Differential, Sonoran Steel Lift System # 7.1, AIRAID MIT, TrueFlow Air Filter, Jardine Cat-Back Exhaust, LT285/75R16 Pro Comp Radial XTerrains
SOLD: '99 TOYOTA 4Runner Base 4WD, 2.7L 4-cylinder with M/T
RR DIFF LOCK is offline
Old 03-13-2007, 10:42 AM   #2 (permalink)
1styota4X4's Avatar
its your belt make sure its tight or replace it....you might be able to get some belt dressing but i am not super fond of it
__________________
NEW***
1985 lifted locked dual cases bumpers and sliders now my daily!
1985 Stock Had to do head gasket and some other minor things left.
1983 Hilux 4X4 SR5 4 Sale
3" Rough Country Lift 32" Goodyear Wranglers. Custom bumpers being made!!
1995 4Runner 4X4 V6 SR5*****TRADED
1styota4X4 is offline
Old 03-13-2007, 10:44 AM   #3 (permalink)
mkgarrison5's Avatar
i was gonna say clean the sh$t out of your under body and motor area. check your tension and maybe spray the belt dressing just to see if it helps. if it does then replace it
mkgarrison5 is offline
Old 03-13-2007, 11:17 AM   #4 (permalink)
lee
lee's Avatar
Send a message via AIM to lee
yeah i bet its the belt... its likely not the bearings because then it would be constant noise, not just when the a/c is on.
lee is offline
Old 03-13-2007, 12:29 PM   #5 (permalink)
Quote:
yeah! clean it up good after ever time you go stump jumpin. i know people like to ride around with sh$t all over their truck bc they think it looks cool but intern its f'ing up your ride.
Old 03-13-2007, 12:40 PM   #6 (permalink)
tampabayota's Avatar
with all that mud you get on the belt it can be like sandpaper and ruin your belt replace and youll be fine
tampabayota is offline
Old 03-13-2007, 12:41 PM   #7 (permalink)
I actually cleaned up the 4Runner as soon as possible, but bear in mind, I had about a 60-mi journey home before I could break out the hose. I guess now is a good time to mention that I must've also caught some small debris / pebbles in the front caliper and there was a horrific grinding sound coming from the front wheels when I was in the mud, until I put it in reverse and apparently loosened whatever was caught in there. Oh, and now my FIAMM horns work at about 10% loudness vs. before the wheeling trip. Nice. Can I just say that going balls out through mud is a mistake I'll never make again...? What a mess, what a hassle...
__________________
Scott - Gilbert, AZ
Old 03-13-2007, 12:44 PM   #8 (permalink)
Quote:
hahah thats why i dont go muddin like that anymore.. if i had a truck on the side i would but mine is my primary vehicle.. just clean it up very very good. grease the fittings and etc. i would detail the piss out of it and just stick with trail riding not so much sandy mud.. in NC we have red mud, it doesnt get allin the calipers and etc. it chucks up and if you arent careful you are stuck up lol
Old 03-14-2007, 04:33 AM   #9 (permalink)
lee
lee's Avatar
ugh, i hate mud, and now you know what
the pebbles in the brakes is common, i get that while going through small water puddles and stuff. shifting into reverse almost always works for me.
lee is offline
Old 03-14-2007, 06:40 AM   #10 (permalink)
techno's Avatar
When I get a squeaky alternator or compressor, spraying wd40 onto them for 2-3 seconds whilst they are running almost always does the trick for me.
techno is offline
Old 03-15-2007, 09:29 PM   #11 (permalink)
Help, I have tried carefully spraying down the belts with water while the engine was running and after the water was spun off, the belts started to squeek again. This is a high-pitched whine and it only occurs when the A/C is turned on. And it is intermittent. It's an ear-piercing sound - my eardrums were ringing after it went off right as I was leaning over the front grill and looking in! Do I need to take the drive belts off and start poking around in there? Please advise.
__________________
Scott - Gilbert, AZ
Old 03-20-2007, 12:52 PM   #12 (permalink)
UPDATE: took vehicle to dealership to fix
Was told there was still mud and debris around the compressor and that the A/C belt was no longer centered on the pulley. Approx $80 to clean it out and re-install the belt. GRRRRR...could've and should've done this myself.
__________________
Scott - Gilbert, AZ
Old 03-20-2007, 12:58 PM   #13 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
Lesson learned, and at least its fixed, right Scott?
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 03-20-2007, 08:44 PM   #14 (permalink)
Yes, lesson learned. And yes it's fixed now. A/C turns on like a charm with no belt squeal. 4Runner also ended up needing an alignment as my specs were thrown way off after bumping and bouncing through that mud. I hit some hard bumps and I'm not surprised the front end was out of whack. $159 service bill today...ouch!
__________________
Scott - Gilbert, AZ
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A/C Compressor turned Air Compressor Kiff 86-95 Trucks & 4Runners 13 08-15-2007 06:59 PM
Turned the BIG 3-0 (and some MUD pics) bamachem 95.5-2004 Tacomas & 96-2002 4Runners 23 10-21-2004 08:38 PM
Look at what i turned this morning. Toddski Off Topic Talk 3 11-03-2003 11:22 AM
Turned 21 NerfHerder-97SR5- Off Topic Talk 5 09-08-2002 05:19 AM
2009 InternetBrands, Inc.
