Please help me troubleshoot my Check Engine light
Old 11-05-2005, 04:58 PM
youngbuck's Avatar
Yesterday I installed URD's Thottle Body Gasket .
While installing, I took out the EFI fuse as recommended. When I started it up a while later, the idle was relatively rough, and the RPMs occasionally bounce between ~500-700. I figured it was no big deal, and that when the computer relearned some things, everything would smooth out. Well, that didn't happen. And this morning, I started my truck, and after a couple minutes of driving it the check engine light came on. I tried taking the EFI fuse out again to see if that would help, left it out for a long time, and it didn't help. I think the check engine light was off for a few seconds when I started it up, but it immediately came back on.
Just a while ago I took it to Autozone to find out what codes it was spittin out.
PO171: The PCM has determined that during testing, the fuel system for bank 1 was too lean. (Ok, so my cylinder 1 is lean.)
And another code, PO300. The guy told me this was a Random/Multiple Cylinder Misfire.
Here are a few other notes that may be helpful:
Amsoil air filter. Cleaned both the throttle body and MAF a couple weeks ago. Gasoline is BP (good stuff from busy gas station), 1/3 87 octane, and 2/3 85 octane (figured it would be ok to throw some 85 in since it's higher elevation. I also put a can of seafoam in this tank of gas. This problem didn't appear until immediately after I put the new TB gasket in.
Thanx in advance!
-YB
EDIT: Problem solved. Sorry for wasting your time. Rotated gasket 90 degrees and all is well.
Old 11-05-2005, 06:25 PM
Travs97's Avatar
maybe some new plugs? or coil
Old 11-05-2005, 07:25 PM
youngbuck's Avatar
I will be putting in new plugs and plug wires in a few days. I'm thinking there may be something else though. Everything is fine while I'm driving, it's just the idle is rough, and the CEL...
Old 11-05-2005, 08:41 PM
humanoid's Avatar
Are you sure you connected all the hoses and stuff? I did the same mod you did and the truck idled really rough. I looked all over for loose connection and finally found a loose vacuum hose right under the throttle body I didn't see when I was removing the TB.
Old 11-05-2005, 09:07 PM
youngbuck's Avatar
I just went and triple checked all of the hoses around the TB, and checked for other loose connections etc. Everything looks good to me.
Old 11-06-2005, 07:10 AM
javadoody's Avatar
check to see that in moving things out of the way you didn't crack a hose or wire.
Old 11-06-2005, 11:15 AM
youngbuck's Avatar
Checked that. Everything is in very good condition.
Old 11-06-2005, 12:17 PM
yamarocket630's Avatar
Did it have the code previously? If not, you probably buggered the TB gasket in some way and now have a vacuum leak. And P0171 is for Bank #1 of the engine running lean, not just cylinder #1. You didnt say what you drive, but most Toyota's only have 1 upstream O2 sensor, so that means the entire engine is considered bank #1.
Old 11-06-2005, 02:27 PM
youngbuck's Avatar
That's what I thought too, but here is what the printout of the tester said:
TROUBLESHOOTING PO171
The PCM has determined that during testing, the fuel system for bank 1 was too lean. (Bank 1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank.)
Sounds like the machine is giving a bad description. It refers to bank 1 as a single cylinder (cylinder #1) and then kinda condradicts itself saying that bank to identifies cylinders (plural) on the opposite bank.
Oh well. I am going to go check out the gasket, and make sure I don't need to rotate it 90 degrees or something. If not, I'll try and see if putting the old gasket back in changes something.
Edit: Forgot to say that I don't think it had a code before. At least everything worked perfect and that there was no check engine light. Also, it is a 2001 Tacoma TRD, 5vz-fe.
Edit #2: Problem solved. Sorry for wasting your time. Rotated gasket 90 degrees and all is well.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Please help me troubleshoot my Check Engine light
