Planning on a Brake Fluid Flush This Weekend
Old 07-16-2004, 03:37 AM
ugadawg95's Avatar
Questions on performing a Brake Fluid Flush This Weekend
I have searched, but most of the posts refer to using the flush machine. I would like to know if there are any alternatives to doing an entire brake system flush without using the machine. If so, how would I go about doing so. Is 3 12oz bottles enough to do an entire flush? From reading other posts, I am going to use DOT3 fluid. If I don't use Toyota fluid, what would you guys recommend? Thanks Yotatechies!
Old 07-16-2004, 05:53 AM
Gadget's Avatar
You might want to sniff over my website for some info.
Gadget
Old 07-16-2004, 06:11 AM
grams72's Avatar
Can I ask why?
Old 07-16-2004, 06:15 AM
Guest
4RUNR's Avatar
You can put something under the pedal so it doesn't exceed normal travel, which is a good amount with the weak 4Runner breaks. Then do the 'ol break pedal method.
Old 07-16-2004, 06:21 AM
rimpainter.com's Avatar
Originally Posted by grams72
Can I ask why?
Why what?
Old 07-16-2004, 06:34 AM
grams72's Avatar
Why would you change your Brake Fluid?
Old 07-16-2004, 06:37 AM
Because over time the seals wear in the MC and calipers, causing the fluid to turn black. Crud starts to build up in the reservoir and lines. Not only that but brake fluid picks up moisture, which decreases its effectiveness. In a nutshell, old brake fluid increases the chances of seal failure and decreased braking ability (see foaming). Hope that helps.
Old 07-16-2004, 06:39 AM
grams72's Avatar
But its a 99
Seems a bit premature. Guess its a piece of mind thing.
http://www.brakesafely.com/brake_flush.htm
Old 07-16-2004, 06:52 AM
But its a 99
True, but we don't know his mileage or brake use. I guess that would help.
Old 07-16-2004, 07:31 AM
Guest
4RUNR's Avatar
I thought brake fluid was a 2 year thing? 1999 would be coming up on the 3rd change!
Old 07-16-2004, 07:37 AM
eric-the-red's Avatar
But its a 99
A 99 means the fluid is 5 years old already. Brake fluid can reach the maximum water contamination after only 2 years. Apart from the lower boiling point more water means more chance of corrosion in the calipers.
I change mine every 2 years, it's cheap and, with the Motive bleeder, easy to do.
Old 07-16-2004, 08:34 AM
Flamedx4's Avatar
Another option for you - I just did mine with a MightyVac. The buddy-pedal-up-down-up-down-up-@#$%-down method didn't work so well. The Mightyvac worked great. But if I hadn't wanted a mighty vac for the other things it does, I would have gotten a pressure bleeder machine - I've seen em work and it makes it mighty easy. I bought the rebuildable MV unit at Harbor Freight for $30.
By the way, I had fresh clear fluid coming out of all 5 bleeders, and pulled out a couple extra ounces at each just for good measure, and used almost an entire 32 oz bottle of DOT3.
Old 07-16-2004, 08:37 AM
Flamedx4's Avatar
Hey eric, just noticed your location. I spent more than one long afternoon trying to drive the one mile across the Port Man Bridge... LOL.
Old 07-16-2004, 08:43 AM
That is one of the main reason's I bought the house in PoCo, could have saved some money buying in Surrey or Langley, but the thought of having to cross that bridge twice a day
Old 07-16-2004, 11:53 AM
ugadawg95's Avatar
Gadget
Thanks!, Thats exactly what I was looking for!
Old 07-20-2004, 09:35 AM
ugadawg95's Avatar
I did the flush Saturday using the brake pedal method. Not bad at all, though time consuming. I ended up using 2 12oz bottles of Toyota Fluid. The braking seems smoother now than before. Maybe its just me??? To date at 65K miles here is what has been done:
Tranny Flush/Fluid Change
Diff Fluid Change
Air Filter
PCV Valve
Plugs
Brake Fluid Flush
Radiator Drain, Flush and Fill
Switched to Mobil1 Synthetics for all fluids (except Brake Fluid)
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
09-04-2015 09:27 AM
MTLroadierunner
07-20-2015 03:07 PM
horunner1x
07-10-2015 06:33 AM
Quick Reply: Planning on a Brake Fluid Flush This Weekend
