Pinging
Old 09-15-2003, 09:02 PM
Toyo4x4's Avatar
Pinging
Getting a lot of pinging under acceleration as well as intermitently on level ground/slight rises. Hate to think what it would do going uphill.
I cleaned the throttle body a few days ago and it seems to be a little worse now so I'll go back and redo it. I'm thinking of getting a timing light and retarding the timing 1-2*.
I've heard its bad to switch octanes as it leads to carbon buildup so i don't want to go that route.
Any other tips/tricks or parts I should check out?
Old 09-15-2003, 09:09 PM
HBoss's Avatar
Changing octane is the fastest way to get rid of pinging. You get more carbon buildup by idling than by changing octane. Anyway, I'd be more worried about what the pinging will do to your engine than with what carbon build-up you'll get.
You can try:
-upping the octane
-replacing spark plugs
-octane booster / fuel injection cleaner
Tacoma1313
08-17-2015 05:44 PM
83flatt
07-02-2015 10:30 AM
bobbybouche
06-18-2015 10:22 AM
rimpainter.com
01-08-2004 06:53 PM
billyhub
10
02-03-2003 05:18 AM
Quick Reply: Pinging
