Pinched Brake Line
Old 03-25-2005, 02:03 PM
Yamaha+Toyota=Fun's Avatar
Pinched Brake Line
I was just under my truck this afternoon and I noticed that one of the hard lines on the rear axle looked smashed and totally pinched off. It is the line that goes from the passenger side drum, to the split, and to the flexable line. I was wondering what options I have on fixing it. Is there a place where I could have a line bent, could i get a universal flexable line to go there, or could I order one? Ill post a picture up later to give you guys an idea where it is.
Thanks
Old 03-25-2005, 02:09 PM
DudeBud's Avatar
You should be able to get some hardline from napa or carquest you will have to bend it yourself and you might have to get metric to SAE adaper fittings
jimbo74's Avatar
you can buy a tool and bend your own, the autoparts stores (not the crappy kragen's or pepboys, although they might have them too) carry hardlines... the tool is pretty cheap then you jsut get yourself some of the fittings and bend away
Old 03-25-2005, 02:12 PM
Sweet, thanks for the quick replys. Do the ends of the line need to be flaired? I think i saw that somewhere.
Old 03-25-2005, 02:13 PM
DudeBud's Avatar
If they have the right fittings no
Old 03-25-2005, 02:18 PM
jimbo74's Avatar
also the tool should be able to flare it, if not there is another tool you get that can flare it... both tools are pretty cheap....
Old 03-25-2005, 05:01 PM
eric-the-red's Avatar
Don't know about the US but up here you can by lengths of line with metric flares already premade. If you can find that just buy the length you need and bend it to fit.
You might also check the stealer, it might not be too much to buy already bent.
Old 03-25-2005, 05:17 PM
rivercat's Avatar
why not get a used one from a wrecking yard?
theking11863
03-19-2016 09:36 PM
09-04-2015 09:27 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Pinched Brake Line
