Pinch weld trimming?
Old 06-08-2004, 04:40 PM
914runner's Avatar
I will probably need to trim my pinch weld when I go with 33" tires twards the end of this summer and thought about a different way to trim it.
Instead of hammering the pinch weld flat, couldnt you grind of cut an inch or two off at a time, put a bead of weld in place of the pinch weld and do this for the whole length of the pinch weld?
Would this work or not? Anyone else have other ideas? I guess im just scared of denting the body and screwing something up LOL.
Thanks
Old 06-08-2004, 04:44 PM
jimbo74's Avatar
that idea is fine and accepted in the wheeling world....
Old 06-08-2004, 04:59 PM
914runner's Avatar
I just thought that this idea would make the wheel well look cleaner and more factory arfter the weld is ground flush and painted.
Thanks for the quick reply!
Old 06-08-2004, 05:20 PM
BruceTS's Avatar
When I did my rig, I used a cut-off wheel on my 4 1/2 grinder. Then cut a groove along a scribed line and removed almost an 1". Afterwards I took my body hammer and pounded the sheetmetal to fit, welding the seam shut. So to answer your question, Yes it can be done.....
Old 06-08-2004, 05:24 PM
BajaRunner's Avatar
Where is a good pinch weld trimming writeup? I will most likely need to do this as well by the end of the summer
Old 06-08-2004, 05:46 PM
waskillywabbit's Avatar
Talking Write-up
I got one on my website for just pounding it flat, but eventually I am going to grind it off and put a bead on it to weld the two pieces together like Bruce did. Nothing to it.
Old 06-08-2004, 05:58 PM
jimbo74's Avatar
i have yet to do the left side of my truck but i took the fender off and just flattened the whole pinch weld... as for the fender in that same spot, i trimmed it in section and then floded the old parts back... that way still having a defined rolled edge instead of a sharp fender...
Old 06-08-2004, 07:00 PM
BeaterToyota's Avatar
Well, this is a bit more than just trimming the pinch weld, but check this out.
Old 06-09-2004, 06:18 AM
Mad Chemist's Avatar
Here's a write-up for you:
1) Get big f'in hammer
2) Pound pinch weld flat
Does that help? Seriously, there's no wrong way to do this, mostly just how it looks when its done. I beat mine flat, and haven't ever walked by, in my best "Queer Eye" imitation, and stood aghast at the ugly pinchweld pounded flat.
Man, I need to get some coffee, I'm being awful catty this morning....
Old 06-09-2004, 07:17 AM
Go ahead and have your coffee, but you are absolutely right about this. It isn't rocket science. Just grab some tools and get the job done.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
tazman1972
11
09-28-2015 10:32 PM
runnermedic
13
09-21-2015 05:20 PM
themightykhoner
09-18-2015 02:28 AM
Quick Reply: Pinch weld trimming?
